Old 08-26-2012, 04:10 PM   #1
Electrical charging problem
First Visit...hello everyone! I have a 2000 Cardinal fifth wheel and having problems charging my new battery. When the trailer is connected to 110 land line it won't charge my battery for the unit. I assume it may be my converter, but owner's manual doesn't tell me where it is located. I have spent a lot of time looking for the converter....Does anyone know where it may be hiding?
Thank you
oldcarnut63 is offline   Reply With Quote
Old 08-26-2012, 04:11 PM   #2
oops it is a 2000
Old 08-26-2012, 04:23 PM   #3
Triguy's Avatar
Originally Posted by oldcarnut63 View Post
oops it is a 2000
Corrected for you.
They can be in a variety of places. Mine is beneath the fridge but I don't know where it is in a Cardinal.
Welcome by the way.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 08-26-2012, 04:54 PM   #4
Herk7769's Avatar
You need to eliminate the current limiter right before the battery first.
Looks like:
Press the black button on the side.
Also if the battery is DEAD (less than 6 volts) the converter will NOT come on in order to protect your camper and the converter. Remove the battery (not physically - electrically by removing the wires) and charge it with a 3 stage battery charger.
HAM CALLSIGN - KC3FFW
Old 08-26-2012, 05:41 PM   #5
If you can find the breakers and fuses, you found the converter. Some Cardinals just inside the door, on right. Others to left pf stairs, down low. Will be behind a slotted/vented door.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 08-26-2012, 08:24 PM   #6
electrical charging issue
Thank you All for your responses.....I did find the converter beneath the refridgerator and behind the electric panel...will be working on it tomorrow to see if I have to replace it.You have all been so helpful....thank you again.
