Old 11-28-2014, 12:55 PM   #41
I replaced the old converter with the one that gljurczyk sent me, and everything works like a charm. The lights immediately peeked up from the dimmer light, which was obviously just the power coming from the battery. Works great when I briefly unhooked from the battery, and the fan now kicks on when under extra load. So if was definitely the converter/inverter. I don't know what caused the old WFCO to blow, but I did unhook from the battery for a long period with just shore power. Would that cause the WFCO to burn out??? Anyway, a huge thank you to gljurczyk, Herk, and everyone else to get me back going again! So happy I came to this forum.
2008 Palamino Puma 29-FKSS
St. Francisville, LA
Don S. is offline   Reply With Quote
Old 11-28-2014, 12:57 PM   #42
TURBS's Avatar
The wfco converters are junk.
They use cheap cooling fans on them that go out prematurely then the converter overheats and eventually quits working.
Hopefully you'll not have any issues with Glenn ' s if you ever start having issues with it install a progressive dynamics converter.
TURBS.
Old 11-28-2014, 01:10 PM   #43
Thanks, TURBS. I would have probably upgraded if I had known for sure it was the converter, but Glenn was gracious enough to give me an offer I couldn't refuse. I suppose I did get 6 years out of the old WFCO, so if I can get a few more out of this one I will be happy.
Old 11-28-2014, 02:07 PM   #44
Herk7769's Avatar
Gratz for getting it fixed (and letting us know) and a big thank you to Glenn for sending you his old one.
Running the converter without a battery in the circuit to moderate the demand could have overloaded the converter.
HAM CALLSIGN - KC3FFW
Old 11-28-2014, 02:09 PM   #45
TURBS's Avatar
Originally Posted by Herk7769 View Post
Gratz for getting it fixed (and letting us know) and a big thank you to Glen for sending you his old one.
X2 on all accounts
TURBS.
Old 11-28-2014, 02:37 PM   #46
As I mentioned earlier in this thread, I checked on WFCO's website and the manuals for multiple models state it is ok to use w/o a battery.
2008 FR Salem 26TBUD
2010 FR R-Pod 171 (2009-2015)
2010 Chevy Suburban
Honda EU3000is inverter-generator
techntrek is offline   Reply With Quote
electric, electrical, power
