Old 11-17-2014, 09:18 PM   #1
Electrical DC Power Problems
Hey, everyone. Brand new to the forum. I have been having some very weird problems with my electrical system in my RV. It started with the lights dimming, then getting bright again. That problem grew to the DC power working part of the time. Then I could not get it to work at all unless I reset the main breaker several times. Now, I can only get DC Power sometimes if I reset the main breaker and flip a light switch at the some time. Then it works well - water pump, refrigerator, everything. BUT, if I flip off that light switch, I loose DC power again. Other times I cannot get the DC power to work at all. Well, not true, it will have just enough volts to set off the carbon dioxide alarm, nothing else. The AC power works great, it is shore power 100% of the time. Bad converter? Bad connection? I have a multimeter, but I have not mastered it use beyond testing the battery (good charge) and wall sockets (good - AC power). I should probably get an electrician, but I haven't been able to find one to get out to my "little" job. Open to any and all suggestions. Thanks.
Don S. is offline   Reply With Quote
Old 11-17-2014, 09:45 PM   #2
KenHwy61's Avatar
Sounds like a bad converter to me. Try to confirm with your meter you have constant 120V AC going into the converter and then hook your meter to the 12V DC side and confirm that the output is consistent. Leave the meter hooked to the 12v side and turn on different things such as lights and pumps and see if the voltage drops significantly. I'm not sure how the light switch plays into all this unless it is somehow shorted and causing a large current draw on the converter. Very strange!
Seasonally in the Grand Marias, MN campground
On the beautiful shores of Lake Superior
Aviator Wright-Flyer#1908
2012 Ram 2500HD CTD
KenHwy61 is offline   Reply With Quote
Old 11-17-2014, 10:10 PM   #3
Thanks. I'm just learning how to use a multimeter, but I will try that soon. I discovered the light switch thing by accident, but it doesn't even have to be the same light switch. Whichever switch I have on when it finally works by flipping the main breaker, if I turn THAT switch off then I lose all DC Power. It is very strange and frustrating. I'm hoping it is not the converter, and I want to try everything before replacing it. Could it possibly be a bad ground or a faulty wire problem? I'm going to pull out the whole unit (circuit panel and converter are all in one) when I check the voltage and check all wires, grounds, etc. Also, when the DC power is working, I do not remember hearing the fan kick on for the converter. I guess that would mean a bad converter or obstruction??? I just don't understand how it can work perfectly some of the time and then have very little voltage the rest.
Old 11-17-2014, 10:23 PM   #4
KenHwy61's Avatar
I would forget the switch portion of the problem. It sounds like switching any load is causing a reaction from the converter. The cooling fan is probably on an internal thermostat and only turns on under a high load condition although it could be that it is supposed to be on and it has gone bad. Intermittent problems on equipment is very common so I'm not surprised when something stops and starts working. While it could be something else, I would focus on troubleshooting the converter.
2012 Ram 2500HD CTD
Old 11-18-2014, 04:43 AM   #5
RPAspey's Avatar
I believe you have a bad converter as well, BUT, get the battery out and properly checked. If your battery is bad then your converter may go into a "self protection" mode and shut down. If the battery is good, then it would have to be the converter. Battery checks are free.
2000 Cherokee 29BH with 6V batteries, LED lights & 400 watts of solar power, flipped axles and raised. 2007 Tundra 5.7L DC-LB with lots of mods. C-co, 8/158th AVN Maint.
RPAspey is offline   Reply With Quote
Old 11-18-2014, 05:36 AM   #6
Witch Doctor's Avatar
I'll attach a couple of way's to check your convertor. Also agree with RPAspey post hope's these help you.
File Type: pdf Manual - Power Distribution Center WF-8900 English.pdf (1.89 MB, 66 views)
Coachmen M/H
Concord
2018 / 300 DSC
Old 11-18-2014, 08:03 AM   #7
Thanks KenHwy61. It sounds like I may be out for a new circuit panel/converter. I will check everything out first, though. Still praying it will be something easy (and cheap!).
RPAspey, the battery checked out fine with the meter, but I assume you mean a load test at an auto parts store. I've read lots of battery posts, and I am confused as to whether you even need to have your battery connected when you use shore power all the time. Some say yes, some say no. The battery is a few years old, so that could be an issue. Thanks.
gljurczyk, I appreciate the step by step voltage check instructions. That will be very helpful.
It might take me a few days to get to it, but I will let you know how it goes. At this point, I might just hope it is just the converter and get off the bucks and get it fixed.
Old 11-18-2014, 08:20 AM   #8
If you find it is your convertor.Let me get on my box again and recommend a Progressive 4600 instead of that WFCO you have for about 35.00 bucks more. Read up on it and you will see why I say this. Good luck.... in fact Ill attach some info....
File Type: pdf Progressive Dynamics Charge Wizard Profile.pdf (165.4 KB, 18 views)
Coachmen M/H
Concord
2018 / 300 DSC
Old 11-18-2014, 08:20 AM   #9
KenHwy61's Avatar
You're welcome and
2012 Ram 2500HD CTD
Old 11-18-2014, 08:43 AM   #10
Flybob's Avatar
You don't say how old the battery is. Make sure there is not a battery disconnect switch. If you can not get to an auto parts store, get a helper.
Disconnect shore power. put test leads on battery and read voltage. Have someone turn on fan or multiple lights then read voltage again. You should see small drop in voltage. if there is a significant voltage drop, battery si going or gone.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
electric, electrical, power
