Old 08-21-2014, 10:10 AM   #1
Stg1's Avatar
Electrical Help
Hi Everyone.
I'm planning a trip to Dumas, TX and need some help. I'm planning to park at some relatives property, They have electric , but I need to know if the circuit is above 30 amps, do I need to do something else, or will connecting a 30 amp box with a breaker work? Thanks in advance. Please help.
Steve and Marlene and 2 Furry Kids. LB (Maltese) Rocky (Border Terrier)
2013 Coachmen Catalina 25RKS 2006 Nissan Titan Crew Cab
Stg1 is offline   Reply With Quote
Old 08-21-2014, 10:28 AM   #2
jtstromsburg's Avatar
Biggest thing is to make sure if you are plugging into a 30a plug, it needs to be 120v, NOT 220.
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 08-21-2014, 10:34 AM   #3
Herk7769's Avatar
Amen brother.
Most home "30 amp outlets" are wired for 220 appliances like welders, compressors, and air conditioners.
Plugging into THAT would be VERY expensive.
HAM CALLSIGN - KC3FFW
Old 08-21-2014, 10:43 AM   #4
DaveSchwartz's Avatar
Of course those other 30 amp receptacles have a different blade configuration. The problems arise when someone thinks they should be wired the same too.
2015 Rockwood Signature UltraLite 8282WS Platinum, GY Marathon LRD, TST 507RV TPMS
2005 GMC 2500HD CCSB D/A, Curt E16, Prodigy P2, Garmin RV760LMT w/BC-20 b/u cam
Self restraint is for the young. I'm old and want it NOW!
DaveSchwartz is offline   Reply With Quote
Old 08-22-2014, 10:58 AM   #5
Stg1's Avatar
Thanks for the help. I just need to know if the circuit is say 60 amps do I need to do something other than wire it to a 30 amp rv box that has a 30 amp breaker? Sorry to be so dumb, but I have limited electrical knowledge,
Old 08-22-2014, 11:04 AM   #6
wmtire's Avatar
This sticky we keep in the FAQ section may help you or an electrician wire it correctly.
http://www.forestriverforums.com/for...let-27223.html
2011 Flagstaff 831 RLBSS
I hate it when people don't know the difference between ur and u'r!
Old 08-22-2014, 12:04 PM   #7
Stg1's Avatar
Thanks for the info.
Old 08-22-2014, 12:32 PM   #8
Take The Road Less Travld
MuddauberE's Avatar
I agree to first test the 30Amp plug with a voltmeter. Make sure it is not putting off voltage in the 220's but only in the 110-125 range. Anything else will blow up all circuitry in the trailer. Being a family members house and they having a 30 amp in the garage, I'm willing to bet that this was probably for a welder or some other item requiring a 220v 30amp plug unless they installed it themselves specifically for a TT. If it is a 50 amp plug, then your plug wont fit. but Why they make a 30amp 120 and a 30amp 220 with the same receptical configuration is beyond me. I have not personally experienced it but I have heard plenty of stories of people who have done this somehow and started a nice fireworks show.
"Take The Road Less Traveled"
2013 Rockwood Roo 233s
2017 Ford F-150 EB
I've been an RVer since 2007, Lifetime Camper
Gotta love the Outdoors, Disconnect and Enjoy Nature!
MuddauberE is offline   Reply With Quote
Old 08-22-2014, 10:46 PM   #9
Another good site is: RV Electric
And for the 12v stuff: The 12volt Side of Life (Part 1)
RedRollingRoadblock is offline   Reply With Quote
Old 08-25-2014, 05:43 PM   #10
TheUO's Avatar
They are not supposed to be the same receptacle...
Travel trailer 30 amp has a specific receptacle labeled TT-30 which has a different configuration that say any of the NEMA 30s (6-30, 10-30 or 14-30). The problem is you can put whatever receptacle you want on when installing and installers are incorrectly using TT-30 receptacles when they should be using a NEMA receptacle for say a dryer/welder/other household item.
This is a TT-30:
Any of these should be used at home for typical household 30amp stuff that isn't your trailer:
NEMA 14-30:
NEMA 10-30:
NEMA 6-30:
NEMA 15-30:
NEMA 18-30:
TheUO is offline   Reply With Quote
electric, electrical
