Old 04-16-2016, 06:35 AM   #1
Chewie's Avatar
Electrical help for my Brother in Law with SOB
My BIL bought a new Thor Quantum Class C, PDI went well but since he's been home, the shore power keeps blowing the house GFI instantly. He's tried multiple outlets on his house to see if there is a change and it keeps doing it. So essentially, there is no shore power. Worked at the dealer a few days ago. I was trying to help him over the phone last night, he was saying he can run everything on the generator, and he also has an inverter that's working but obviously killing the batteries after a while. From what I can gather he's using the 30a cord stepped down to 15a adapter and extension cord. He wasn't trying to run any big appliances on the 15a, just outlets and TV. Other than checking for breakers tripped or blown fuses, what else should I look for? I'm heading over today there to try and help out. We have a trip in 5 days so we want to get it working on shore power. Thanks.
I used to have a really nice motorhome
2016 Jeep Wrangler Unlimited
Chewie is offline   Reply With Quote
Old 04-16-2016, 06:47 AM   #2
clr
Plugging a RV into a GFI outlet is not a good idea. The explanation for not using a GFI outlet is long, but your house is earth grounded and your RV is a floating ground system. You should not mix the two grounding systems. Also you should not have a GFI system feeding another GFI system. All RV's have at least one GFI wiring circuit. My first action would be to plug the RV into a non GFI outlet in the home and see if that works. Second I would make sure that the extension cord is able to handle the 15 amps. You should not use a standard 16 or 18 gauge extension cord to plug in the RV. I would recommend a 10 gauge or at least 12 gauge. All so the extension cord should be as short as feasible.
clr is offline   Reply With Quote
Old 04-16-2016, 06:51 AM   #3
nomad297's Avatar
Exactly my thoughts.
Bruce
nomad297 is online now   Reply With Quote
Old 04-16-2016, 06:56 AM   #4
Chewie's Avatar
Ok, thanks. I will take my power cord along to see if it works any different
Old 04-16-2016, 07:14 AM   #5
X2. No reason for a GFI feed to the RV, it is not designed for this. It has it's own GFIs where necessary. Straight feed from the house. There is no tie between ground and neutral in the RV circuits and serial GFIs are a bad deal.
2015 335DS
ScottBrownstein is offline   Reply With Quote
Old 04-16-2016, 07:23 AM   #6
shughey00's Avatar
deleted....answers were given above by the time I was done typing so... No need to repeat. Use a non GFI outlet is all.
shughey00 is offline   Reply With Quote
Old 04-16-2016, 07:47 AM   #7
You might want to take your dog bone adapters in case BIL has an issue with his. It's just one of the variable that changed since leaving dealer.
2016 Ford F250 XLT 4X4 6.2L
Hensley Arrow
Nights camping in 2017: 20 nights
Miles traveled in 2017: 1,530
uhduh camping is offline   Reply With Quote
Old 04-16-2016, 08:50 AM   #8
Chewie's Avatar
Yes I did bring it. Just in case. I should be there around lunch time and hopefully it's something simple and I'll follow up. Thanks
Old 04-16-2016, 11:40 AM   #9
At home I use a 20 Amp GFI for my shore power with no issues. I had a similar problem to what Chewie is describing. The trailer was still winterized so there was no water in the hot water tank. I had forgotten to turn off the electric to the water heater. The element would overheat and trip the breaker, in my garage, shortly after plugging in. Doh. Lesson learned.
2015 Solaire 201SS
2015 GMC 2500HD Duramax
PSU Turf is offline   Reply With Quote
Old 04-16-2016, 01:53 PM   #10
Chewie's Avatar
Update, I have since switched him to an outlet inside his house, non-gfci, working on shore power. The instant the cords are connected to the gfci it trips. Even though all the breakers inside the motorhome are off. No blown fuses, breakers seem fine. I believe it's his house??
electric, electrical
