Old 06-29-2015, 08:44 PM   #1
GATOR 7
Electrical issue
I have a 2013 360PDEK SIERRA when at home I cannot plug into 30 amp with the slide outs in, if I extend the slide outs then plug in all is good but if I retract slide outs and try to just plug in to keep fridge cold it will trip breaker. Any suggestion or am I doing something wrong? Thanks
Ukbirs is offline   Reply With Quote
Old 06-29-2015, 08:51 PM   #2
dan-nickie's Avatar
Is this just at home?
What about at campgrounds?
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 06-29-2015, 09:19 PM   #3
KMP44's Avatar
That's an unusual issue. What breaker blows - the one in the house? Wonder if maybe there is a bare wire that gets pinched or contacts the frame when the slides are in causing a short. Just a wild guess...
2017 F-250
2013 Rockwood Roo 23 IKSS
KMP44 is offline   Reply With Quote
Old 06-29-2015, 09:22 PM   #4
Crusadernoob's Avatar
I would leave all slides out, plug in and move one slide in at a time until something gives, would be my first thought, then start checking under that slide for pinched wires.
2006 2500HD CCSB 2WD 2014 Crusader 285RET
Nights camped in 2013 - not enough!, 2014 37, 2015 40, 2016 39, 2017 38, 2018 14
Crusadernoob is offline   Reply With Quote
Old 06-30-2015, 12:37 PM   #5
GATOR 7
I haven't tried it at campground I usually put the slides out and then plug in I will try this weekend. Thanks
Old 06-30-2015, 12:39 PM   #6
GATOR 7
It usually kicks the gfi in my garage thought maybe it was just that GFI but I tried plugging in on another same thing
Old 06-30-2015, 12:42 PM   #7
GATOR 7
Thanks. I will try this when I get home again thanks for the suggestion
Old 06-30-2015, 03:36 PM   #8
KMP44's Avatar
Might also want to try plugging into an outlet that is not gfi protected. Even if its not the gfi plug, if its on the same circuit it may also be protected. Plugging the camper into a gfi protected outlet can cause breaker issues. Might have to run the cord into the house for a test, but if you don't have the issue at the cg, I would try that.
2017 F-250
Old 07-01-2015, 09:05 PM   #9
GATOR 7
Thanks to all that gave advice. I was able to locate and repair the problem. There was a wire being pinched by one of the slide outs and upon close inspection the problem was very visible. It has been repaired off to the lake. Thanks
electric, electrical
