Old 02-25-2012, 02:54 PM   #1
Bearcat55's Avatar
Electrical issue......I think?
I just brought my new 2012 Salem 30kqbss home today. Went through the demo at the dealership and everything worked perfectly. I took the camper to our storage yard in order to laod everything from our old camper into the new one. I plugged in our generator in order to have heat since its a bit cold outside today. Now the slide, electric awning, and electric jacks will not work. So i unhooked the genny . I tried the breakers, all ok. I looked at fuses, all ok. I called the dealership and the sales rep said it could be the in-line fuse behind the battery, Impossible! The 12volt lights are all working without issue. Any ideas on what this could be????Thanks!!
2012 Salem 30KQBSS
2010 F150 S-Crew 4x4 5.4L
Bearcat55 is offline   Reply With Quote
Old 02-25-2012, 03:10 PM   #2
TURBS's Avatar
YES It could be an inline fuse behind battery . There could be more than one positive cable coming from the the positive side battery . Mine has more than one.
there is or should be a resettable circuit breaker behind battery or close to it .
just curious did you check the circuit breaker on your gennie ?
Old 02-25-2012, 03:52 PM   #3
Bearcat55's Avatar
Yeah, genny was working fine, but dealer says slide should operate on battery power. I checked and I only have one positive line running from battery. I couldn't find any resetable breaker near battery. Behind battery under frame is a junction box with a lot of wires tied together with wire nuts but no fuse that I can see anywhere.
2012 Salem 30KQBSS
Old 02-25-2012, 05:09 PM   #4
bikendan's Avatar
should be a resettable breaker. it has a button on the side of it, to reset it.
mine is along the tongue, between the battery and the front of the trailer.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 02-25-2012, 08:45 PM   #5
Bearcat55's Avatar
Ok found 30 amp breakers under front end but they were not tripped. I have tried almos everything to no avail. All appliances, lights, and furnace work, just not the awning, jacks, or slide. I'm starting to get concerned about my purchase!!!
Update: I'm now plugged in to 30 amp service and no changes!
2012 Salem 30KQBSS
Old 02-26-2012, 09:34 AM   #6
TURBS's Avatar
Did you check power on both sides of circuit breakers to see if ones bad?
Old 02-26-2012, 10:09 AM   #7
Bearcat55's Avatar
My brother in law the electrician is coming over today to check it out. It's probably gonna cost me some beer and a dinner, but hopefully it's worth it. I don't wanna tow it back to dealer and take a day off work
2012 Salem 30KQBSS
Old 02-26-2012, 10:29 AM   #8
Hob
Have your wife tow it to the dealer for you. Mine tows our trailer. The first time she did it I told her she couldn't learn to do it any younger. She did great.
Hob is offline   Reply With Quote
Old 02-26-2012, 12:31 PM   #9
sherdep's Avatar
Doubt you have to be concerned with your purchase cause it was working before you hooked up the generator
What plug did you plug your camper into on the generator - hopefully not the 220 side
Hopefully it is something simple and most likely is something simple since you knew it was working prior to hooking up the generator.
Did you turn the breaker off and then turn it back on - I have seen breakers pop but still look like they are on and the only way to reset them was to turn them off and then pop back on.
When I hook up my generator - I shut the main breaker off in my load center since my generator does not have a breaker or switch to turn the power on or off.
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 02-26-2012, 12:34 PM   #10
Bearcat55's Avatar
Back to the dealer it is. 30 amp breakers in front have power but it goes away somewhere underneath the trailer. Checked power going into jack motors and no dice. Same with the switch controlling the slide.
2012 Salem 30KQBSS
