Old 09-28-2014, 11:13 PM   #1
Electrical issue on shore power but works fine on generator
We're camping in New Mexico, and I have the following problem:
On generator: all circuits and appliances work, the house battery charges up, inverter panel shows AC in, inverted circuits work
On shore power: GFCI circuits in bath, kitchen, and basement do not work, front air conditioner does not work, batteries do not charge, inverter panel mid-coach does not show AC in, inverted circuits work.
Any ideas? Transfer switch?
2009 FR Berk 390BH
Moose
2009 FR Berkshire 390BH
jbramhall is offline   Reply With Quote
Old 09-29-2014, 10:46 AM   #2
jk510's Avatar
Maybe a silly question but, have you checked the power at the pole? They are not always the most well cared for item in the park. You need a volt meter (DMM) and check both L1 and L2. If your rear AC is working it sounds like one of the Ls is dead.
Joel K
Southeast AZ
2013 Coachman Mirada 29DSSE
jk510 is offline   Reply With Quote
Old 09-29-2014, 10:50 AM   #3
wmtire's Avatar
X2. On a 50 amp RV, in simple terms you have TWO 50 amp 120 volt lines feeding the RV. It does sound like one of the lines is not working correct...thus only some of your stuff working, that may all be on the non functioning incoming line.
As jk510 stated above, the first place to check is the pedestal at the park.
This link will help, and click the outlet testing tab on the left:
http://www.myrv.us/electric/
The voltage between Y and X should be 240-Volt, X and W 120-Volt, Y and W 120-Volt, X and G 120-volt, Y and G 120-volt, W and G 0-Volt
You may find either the Y(L1) or X(L2) is not giving you 120 volts.
You can also have the same thing happening in your power cord, and only one leg is coming all the way in to the RV. We see bad/burnt power cords pretty frequently here in the forums....especially when owners don't twist them good for the final lock, or connect/disconnect the cords without killing power at the pedestal first. Over time, the electrical arcing that occurs will make either the cord, or the attaching point to the RV unworkable.
I would check the campground outlet first. If that checks out, then plug your detachable RV cord into the outlet, but not to the RV. Check the cord now. This way you can eliminate each link in the power chain, as to where the problem lies.
If the cord checks out, then you know the problem lies from where the cord attaches to the RV and in from there.
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 09-29-2014, 10:52 AM   #4
TURBS's Avatar
Bad transfer switch?
Only one side engaging on shore power?
Only one leg hot on pole?
Turbs
Old 09-30-2014, 02:39 PM   #5
Sorry, bad internet connectivity last couple days.
An update, I opened up the transfer switch and found melted contacts! Lucky we had no fire. I found a replacement part in Flagstaff and we'll drop the coach for a day while we sightsee there. Here's some pictures...Click image for larger version
Name:	ImageUploadedByForest River Forums1412105949.684416.jpg
ID:	63856Click image for larger version
Name:	ImageUploadedByForest River Forums1412105965.806106.jpg
ID:	63857Click image for larger version
Name:	ImageUploadedByForest River Forums1412105977.322476.jpg
Moose
Old 09-30-2014, 02:45 PM   #6
Kaadk's Avatar
You got lucky. That looks like it could have gotten real ugly, real fast.
I've never taken a look inside a transfer switch. I would have assumed to find relays that handle the switching. Instead, this looks like it's just bridging the two connections into one output. In that case I'd be worried about plugging into shore power with a generator running.
The surest way to lose is to play Marco Polo with a ventriloquist.
Kaadk is online now   Reply With Quote
Old 09-30-2014, 03:27 PM   #7
TURBS's Avatar
Hey I got one right!
Do I win a prize?
Or does this just make my wrong from another thread just equal out?
Turbs
Old 09-30-2014, 03:36 PM   #8
You got it!
I put a cheap smoke detector in the bay with the transfer switch, and I have not plugged in to shore power for 2 days. I run the generator at the end of the day only to bring the batteries up for over night for lights when we're in the coach. I think the risk of fire is highest on shore power, lowest on battery, and middle risk on generator. I only run the generator when we're awake and near the coach. I have the fridge and hot water running on gas. The real pisser is that the coffee machine requires good power!
Moose
Old 09-30-2014, 08:49 PM   #9
The photos show why OSHA requires arc flash protection when opening electrical panels that are energized. This is one government rule that makes sense. Suppose you had the panel cover off and were troubleshooting it when the arc happened? I've seen videos of arc flashes using dummies in front of an open panel. The arc spews out molten metal and it gets ugly really fast.
The smoke detector in the electrical bay is a good idea. On our Sunseeker, it's directly underneath the bed. That's not a comforting thought. I just hope the metal box contains the arc if it happens!
RamblerGuy is online now   Reply With Quote
Old 10-01-2014, 11:03 AM   #10
jk510's Avatar
HOLY CRAP!! That's Ugly!!
I have to wonder what caused it. That shouldn't happen in normal operation. Did you take any powerline hits? Wow.
Joel K
Southeast AZ
electric, electrical, generator, power
