Originally Posted by gano799
Having an electrical issue...Battery will not charge when hooked into shoreline power and LP/CO2 detector beeping every 15 seconds and saying low voltage/malfunction when fully hooked up..Anyone else have this issue? I think it's either I need new house batteries or maybe a new converter?
That is a sign that the converter charge is not reaching the battery(ies).
However there can be other cause besides the converter or the battery.
Do you have a factory or self installed battery shutoff/disconnect? If so, is it on or off?
Have you recently disconnected the battery (or reconnected it)?
Have you checked the resettable circuit breaker (if equipped)?
As Dan pointed out, we need to know what RV you have to really be of assistance. We have no idea if you have a popup, tt, motorhome, etc at this point.
