Old 07-13-2016, 12:18 AM   #11
We've had it since it was brand new, 9 years. Everything has always worked. And were working fine until we lowered the electric stabilizer jacks. The jacks power quit and so did the lights and fridge.
laurenk0411 is offline   Reply With Quote
Old 07-13-2016, 12:18 AM   #12
Where would the 12v shut off be located?
Old 07-13-2016, 06:17 AM   #13
TURBS's Avatar
Check for a self resetting circuit breaker by the battery.
It may has a red rubber cover.
I have three as shown.
One or more has tripped.
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
2016 nights camped "14"
Old 07-13-2016, 03:31 PM   #14
This is the clue that tells what happened. The jacks present a high current draw on the battery. If the battery voltage is low, the jacks should draw more current than normal which, as already pointed out, probably tripped a circuit breaker or blew a master fuse located near the battery.
I'd start at the battery with a voltmeter. you should see 12V or more. Next check the distribution panel where the fuses are. If there's no voltage there, the issue definitely lies between the battery and the distribution panel.
Phil
pmsherman is offline   Reply With Quote
Old 07-13-2016, 04:28 PM   #15
rracer5's Avatar
2015 Columbus 320RS
2008 2500HD Duramax
They could also be manual reset. After you check for proper voltage look for the breakers. When you find them, run your finger around the sides of the circuit breaker til you feel a small button (very small & doesn't stick out very far). Press the button and see if everything comes back on.
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 07-13-2016, 04:46 PM   #16
Check the inverter make sure it is turned on the same thing happened to me something bumped into the on off switch
Brightowl is offline   Reply With Quote
Old 07-13-2016, 05:21 PM   #17
Lights
Have you tried plugging into your tow vehicle and see if lights come on. I had a similar issue and the converter had went bad, killing batteries. As has been said, check voltage at batteries and go from there.
traindrv is offline   Reply With Quote
Old 07-13-2016, 06:30 PM   #18
TURBS's Avatar
Sorry that's what I meant.
Manual reset
2015 Columbus 320RS
2008 2500HD Duramax
Old 07-13-2016, 06:30 PM   #19
TURBS's Avatar
Inverter would have nothing to do with it.
2015 Columbus 320RS
2008 2500HD Duramax
Old 07-13-2016, 06:33 PM   #20
TURBS's Avatar
The jacks are almost always hooked directly to the battery, with a circuit breaker like I've shown, a lot of times internal 12 items including the converter are also on those manual resetting breakers.
If the landing gear quit then I'd suspect that.
2015 Columbus 320RS
2008 2500HD Duramax
electric, electrical, fridge, light
