Old 01-16-2013, 01:04 PM   #1
daydreaming about camping
jeeplj8's Avatar
electrical option - not enough juice for everything
In the few trips we have managed in our new trailer, we have already seen a problem brewing with not enough juice to run everything we want running.
Our trailer is set-up with 30 amp service. Twice, in the mornings, we have had trouble with blowing multiple breakers. Typically what happens is the hot water heater (gas/electric) is running and the fireplace is running. Then we try to make coffee and blow a breaker. We have blown the 30 amp campground breaker twice, so I am guessing the hot water heater and fireplace pull a little more juice than I thought. Since this is the morning routine, we would like to be able to run all the above at once.
The purpose of this thread is kind of brainstorm ideas on how to go about avoiding this in the future. The first idea I have had is to install 50 amp service, and separate the hot water heater and fireplace.
Other ideas?
2013 Coachmen Freedom Express 320BHDS pulled by a 2005 F250 King Ranch CC
A rainy day camping is better than a sunny day at work.
jeeplj8 is offline   Reply With Quote
Old 01-16-2013, 01:12 PM   #2
TURBS's Avatar
Hw heater on gas only would help
Turbs
Old 01-16-2013, 01:13 PM   #3
jeeplj8's Avatar
Turbs
too expensive. can't afford the divorce. DW and daughter need their hot water.
Old 01-16-2013, 01:18 PM   #4
TURBS's Avatar
normal appliance amp draws
Old 01-16-2013, 01:24 PM   #5
TURBS's Avatar
Lol show them the shower house
Turbs
Old 01-16-2013, 01:35 PM   #6
wmtire's Avatar
What Turbs is pointing out, is you can turn the electric portion of the hot water heater off...and just run the hot water heater on propane (which actually heats the water faster than electric only)
A lot of the hot water heaters are what you call dual-powered. They can be run off of electricity, or propane, or both at the same time
2011 Flagstaff 831 RLBSS
I’ve lost my scapegoat.
Old 01-16-2013, 01:37 PM   #7
TURBS's Avatar
Old 01-16-2013, 01:46 PM   #8
jeeplj8's Avatar
I read him OK - we typically have both turned on in the morning for the much faster regen rate. I turn the gas off at night, when nothing else is running, then run gas only during the day, when other stuff is running. but in the morning when the hot water heater is being worked hard I have both on.
Old 01-16-2013, 01:47 PM   #9
jeeplj8's Avatar
Turbs
again - way to expensive, have you priced funerals lately?
Old 01-16-2013, 01:49 PM   #10
wmtire's Avatar
What he said
LOL
Jeep, I need to add that you will have to learn how to manage power, especially with a 30 amp trailer. You are correct, that you cannot run lot's of things at the same time with out exceeding your breaker(s) capacity.
Besides your air-conditioner, things that make heat are your biggest energy consumers. Electric heaters, hot water heaters, toasters, coffee pots, hair dryers, microwaves, etc. are good examples.
A lot of people will run an extension cord from the camp pedestals 120 (20 amp) outlet into their trailer, to run some things off of (like your coffee maker), which will take some of the load off of your trailers 30 amp.
