Old 08-31-2013, 06:09 AM   #1
Electrical outlet stopped working
Hello, I have a 2008 Georgetown 340 motor home. Does anyone know how many outlets are connected to the ground fault? The kitchen outlet stopped working, but the bathroom one and the outside one still work. Any suggestions?
hapecmpr is offline   Reply With Quote
Old 08-31-2013, 07:13 AM   #2
MC9
Usually there are 4 outlets on each GFCI. You probably have two GFCI's in your rig. Find the offending one and press the button.
MC9 is offline   Reply With Quote
Old 08-31-2013, 05:42 PM   #3
only 3
I've only found 3 with 1 circuit breaker. The GFI is in the bathroom. There is an outlet outside which is controlled by the GFI. there is 1 other outlet in the kitchen which stopped working and that's where the wire ends.
Old 08-31-2013, 06:37 PM   #4
Reset the GFCI and check all the outlets for power. Then push the GFCI test button (don't reset) and recheck all the outlets. Any that worked before and don't work now are protected by the GFCI.
Old 08-31-2013, 06:49 PM   #5
Thanks. I realize that but I'm trying to find out why this one stopped working so I can fix it.
Old 08-31-2013, 07:01 PM   #6
It wasn't clear from your original post exactly WHICH outlets your're talking about and which ones, if any, are GFCI outlets. On my Roo, the GFCI is built into the breaker, not the outlet. You might want to check your breakers.
Old 09-21-2013, 10:52 AM   #7
I have a 2003 Georgetown and have outlets not working, 2 inside and 1 outside, have checked breakers and gfi, Please help....Running out of ideas.
dick98837 is offline   Reply With Quote
Old 09-21-2013, 11:43 AM   #8
You may have a defective GFCI. Is the GFCI outlet one of the ones that's not working? When you press the test and reset buttons does it "click"?
Old 09-21-2013, 12:07 PM   #9
BillyBass's Avatar
I had the same problem I had power to the mw and ac but no power to the outlets. I took off the breaker box cover off and the wire to the gfi was hot and loose I tighten it back up and I had power good luck let me know if the was the problem
2012 21' FR Micro Lite FBRS
2005 GMC Sierra 1500
2012 24 nites 2016 16 nites
2013 25 nites 2017 19 nites
2014 14 nites
2015 16 nites
BillyBass is offline   Reply With Quote
electric, electrical
