Old 04-25-2016, 08:22 PM   #1
Electrical outlets not working
I took my Rockwood 2604 in to have a shower leak repaired, now, none of the electrical outlets are working. I checked all fuses are good, Is there a ground fault breaker else were?
california3201 is offline   Reply With Quote
Old 04-25-2016, 08:34 PM   #2
bubbles's Avatar
Your electrical outlets are 120 volt AC and would be powered via a circuit breaker (CB) not fuses (at least would be first for me to learn otherwise). You must have a CB panel somewhere.
Old 04-25-2016, 08:45 PM   #3
RSchleder's Avatar
Did you check out your GFI's? Could have 2-4 of them depending on your particular trailer. Also, as suggested above, are any breakers "tripped"?
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
RSchleder is online now   Reply With Quote
Old 04-25-2016, 08:49 PM   #4
Flybob's Avatar
Check bathroom, near kitchen sink, and outside outlets for CGFI. FR uses one CGFI to protect several outlets.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 04-25-2016, 09:06 PM   #5
raspivey's Avatar
Yep, had that happen on my 2104S. GF in the bathroom took every receptacle out.
Old 04-26-2016, 12:35 PM   #6
None work on shore power? There are at least two ground faults, one in the kitchen and one in bathroom by the sink. Fuses have nothing to do with the 110 VAC. You need to reset the circuit breakers. Shut them all off then turn them all back on. Do them all in case they are not labeled properly. You will have a ground fault for each breaker marked GFI. There will be at least two, maybe three if you have one outside.
The reason I say to shut the breakers off then turn back on is sometimes a breaker trips but it doesn't look like it is tripped.
If you have no ac power check your power pole , or source.
Jim
07 Dodge 1500 crew cab with 20" wheels, 08 Forest River Rockwood Signature Ultra-lite 8280SS
"The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man."
George Bernard Shaw
oldtool2 is offline   Reply With Quote
Old 04-26-2016, 12:54 PM   #7
If you have more than one GFI outlet in your camper and neither is working, it is more likely at the source. The very first thing I would be checking is the shore power to the camper. If it is plugged into a GFI circuit at the house/garage, that could be tripped. Check your source of power panel (main breaker panel at the house). I have seen tripped circuit breakers that are not showing red. Flip them off, then back on. Check your power cord. If using an extension cord, that may have pulled loose. Sometimes, it the most obvious things that can cause the grief.
PenJoe is offline   Reply With Quote
Old 04-26-2016, 01:22 PM   #8
mike.t's Avatar
GFI.
2015 Salem 27RKSS
2015 Ram 2500 CC 4x4 Cummins
55' Chevy Bel-Air
Burgers on the BBQ and a cold beer
mike.t is offline   Reply With Quote
Old 04-26-2016, 01:28 PM   #9
wmtire's Avatar
As others have stated the outlets are daisy chained off one or two GFCI outlets.
However, can I ask if the microwave display is on? This gives a starting point as to where to start checking for power problems.
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 04-27-2016, 08:17 AM   #10
Wolverine 1945's Avatar
Microwave display is always the first place I would look !!!
Wolverine 1945 is online now   Reply With Quote
electric, electrical
