Old 08-28-2013, 12:33 PM   #11
Denver, CO
garbonz's Avatar
Install a 12 plug in the camper somewhere and use a 12volt fan. THe endless breeze are good, and HERC's option to.
They draw about 2-3 amps so will use 15 or so amps in 8 hours, The furnace will use 4 or more when running, so you may consume as much 35-0 amps overnight with these two sources. A stock battery will get pretty depleted, unless you are carefull and monitor closely.
2017 Fuse 23T
Old 08-28-2013, 03:58 PM   #12
Thanks for all the info. It's helped out a bunch.
Josh7099 is offline   Reply With Quote
electric, electrical, power
