Old 06-24-2016, 08:16 PM   #1
electrical problem
totally confused. opened up pop-up getting ready for the 4th. plugged into shore power. house breaker keeps tripping. shut down 15A & 20A for ac. reset house breaker15a trippes house. reset 20a a/c works fine . where is the problem. gfci in trailer. help
brobinson0857 is offline   Reply With Quote
Old 06-24-2016, 08:23 PM   #2
raspivey's Avatar
What is the 15A going to? I'm leaning towards electric water heater.
Old 06-24-2016, 08:31 PM   #3
Flybob's Avatar
Could be a few things. Is there a GFCI on the house circuit you are plugging into. Sometimes two GFCI's don't play well together. If not look at WH . If you left the electric mode on without being full of water it burned out the element and shorted it.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 06-25-2016, 07:36 AM   #4
HWH gas no elect. shut off breakers in trailer. reset house breaker. when reseting trailer 15A lights com on then breaker tripps in house
Old 06-25-2016, 07:37 AM   #5
have had this trailer for 16 yrs and never had this happen
Old 06-25-2016, 08:09 AM   #6
problem solved. i must have a weak gfci in house. plugged trailer power to another circuit everything works. have a happy 4th
Old 06-25-2016, 08:12 AM   #7
SeaDog's Avatar
Thanks for letting us know what solved the problem
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 06-25-2016, 08:17 AM   #8
Flybob's Avatar
Trailer most likely has one GFCI somewhere ( unless very old) As soon as you energize circuit that contains the GFCI it probably trips the house breaker. If the house circuit it is on now does not have a GFCI then odds are that is the real problem.
TST Tire Monitors
2 100W solar panels
electric, electrical
