Electrical problem
I have a sunseeker 2900 class c rv. While boondocking this weekend I developed an electrical problem.
The first indication I had a problem was when the "check" light was illuminated on the fridge. While troubleshooting that I realized I had no DC voltage.
I checked on the "info center" and the battery LED was at zero. I tried to start the generator, but it would not start, so I started the engine on the RV. After about 2 minutes I was then able to start the generator and I let it run for about an hour but according to the "info center" readout that didn't charge the battery level...???....so I turned off the generator and started the truck again. After about 2 minutes (again) I could here what sounded like a relay clicking and the "info center" read full voltage and everything worked ok...bright lights, fridge, heat etc. ... but this only lasted for 3 or 4 hours and each time I could start the engine, wait 2 minutes and the batteries would read and act is if they were full....I have two batteries and whatever factory installed inverter/charger...we did spend one night plugged in and everything was perfect.
Thanks in advance for any help!!!
T
