Old 06-25-2012, 07:09 PM   #1
Sg6923's Avatar
Electrical Problem
I took my 3625RT 5er out last weekend to the same campground we've gone to for years. I hooked the 50 amp cord up and went in to run the slides out. I noticed smoke rolling out if the microwave. I ran out and shut it off, unplugged the microwave and plugged the camper in again. I went in and checked the voltage meter I keep plugged in the 120V outlet. It was all the way over and pegged out on the right and getting very warm. The fuse box switches were in the ON position. The repair center gave a quick look with a 30 amp plug and said my fridge, microwave and AC wouldn't work. All the 12 volt systems seem to work.
Does anyone know what the heck happened? The host.checked the box at the campground and said voltage was okay.
I unplugged and came home.
Thanks,
T-man & Sugar
Sg6923 is offline   Reply With Quote
Old 06-25-2012, 07:55 PM   #2
Herk7769's Avatar
This is a classic "Open Neutral"
This results in 240 volts in the camper.
Most likely since the campground checked out ok, the problem is either in your power center or the back of the 50 amp cord socket (or gang box).
HAM CALLSIGN - KC3FFW
Old 06-25-2012, 08:42 PM   #3
MIKE44460's Avatar
If I was the camp ground I too would of said, I'm good here, must be your equipment. You may be looking at a big expense. I would of had someone check their power before you pulled out. I carry an amp probe and meter and will check voltage before I plug in.
Mike & Lu Anne
& our Jack Russell 'Genny'
2011 Flagstaff 831FKBSS
2011 Chevy CC Duramax Z/71
OH plate GM DMAX
Hensley Arrow
MIKE44460 is offline   Reply With Quote
Old 06-25-2012, 08:45 PM   #4
MIKE44460's Avatar
Herc, what does a neutral have to do with 240AC?
Mike & Lu Anne
OH plate GM DMAX
Hensley Arrow
Old 06-25-2012, 08:49 PM   #5
DDC
DDC's Avatar
I would imagine this is why some of us use a Surge Protector with Voltage Protection although if the fault is in the tailer it would not help either.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is offline   Reply With Quote
Old 06-25-2012, 10:09 PM   #6
Sg6923's Avatar
Thanks for the info. Pretty sure he's on the up and up. I watched him check it and others around that we're hooked up. It had the same readings as the others. Thanks.
Old 06-25-2012, 10:38 PM   #7
A 50A connection should be similar to the power coming into your house. You probably have three wires: a neutral, and two hot wires. You get 120V between each hot wire and the neutral. If you measure between the hot wires, you'll discover that you have 240V. This is caused by the two 120 hot lines being out of phase with each other. A ground is generated by connecting the metal fuse/circuit breaker box to a water pipe which is buried in the ground. (Interesting question - what about new houses using plastic pipe? They'll require a grounding rod system to meet electrical code standards.) Since your motor home doesn't have a buried metal water pipe to provide a ground, the campground needs to provide one for you. This creates the four pronged 50A outlet.
If the neutral line is disconnected at the campground connection and you have an active electrical device connected to each of the hot lines, then 240V will appear across the two devices. If both were 100W bulbs, you could get away with this but when the devices have different wattage ratings, the current flowing in the device with the higher wattage rating will be greater (and can be much much greater) than the designed rating of the device. This was the cause of the smoke you saw.
When you connect your campground hookup, two devices are usually immediately powered up; the refrigerator and the converter. It's very likely that they are on different hot lines of the 50A circuit and could cause this problem. If you have a TV with "instant on", it also starts drawing power as soon as the AC appears at the plug.
Understanding how AC power works and knowing how to use a meter that lets you check each "circuit" in a 50A outlet will prevent this problem. When I check an outlet at a campground, I check each hot line to neutral for 120V, check across the hot lines for 240V, then check for voltage between neutral and ground. If no voltage between neutral and ground, I check the resistance between neutral and ground to verify that they're bonded together somewhere before the outlet. The neutral line is normally grounded at the power company's transformer that converts the (usually) 3Kv supply line to the lower voltage supplied to the campground. A large campground is more like a housing subdivision and may have multiple transformers and ground points. Bad connections at power poles can have interesting effects on outlets in one area of a park but not in others.
Phil
pmsherman is offline   Reply With Quote
Old 06-26-2012, 11:18 AM   #8
MIKE44460's Avatar
Phil, if you don't have a nuclear reactor in your basement, you should. Thanks for a very informative reply. Something I will do, for sure, from now on.
Mike & Lu Anne
OH plate GM DMAX
Hensley Arrow
Old 06-26-2012, 12:14 PM   #9
Herk7769's Avatar
Phil's reply was perfect. Thanks were sent (and sent again here).
If the neutral fault is in your camper (at the main circuits), it is possible to have an issue at the power center in your camper that would not show up at the pole. 240 VAC could still appear across some circuits depending on how the power center was wired, if the white neutral came loose at the common buss. The connection between the two "hots" would then be through the ungrounded "neutral" buss.
The damage will be the same; just the campground would have an "out."
Old 06-26-2012, 04:30 PM   #10
It doesn't require a nuclear reactor. What got me started was the standard college preparation high school program I went through:
4 years math
4 years english
4 years history, social studies, government
4 years sciences
4 years gym
2 years foreign language
2 years mechanical drawing
1 years freehand drawing
2 years machine shop
1 semester each - woodworking, foundry, commercial printing, tinsmithing
Round that off with a stint in the military, a couple of college degrees, a 45 year marriage, two independent adult children, a 50 year interest in amateur radio (including climbing a 100' tower and helping install a repeater antenna on another that was hot with 50kw of RF energy), a lifelong interest in photography and astronomy, 35 years as a DIY homeowner (painting, woodworking, carpeting, plumbing, wallpapering, electrical work, masonry, and tree removal), 25 years as a member of the National Ski Patrol, and over 20 years of IBM selling my IT skills by the hour and I figure that by now I have the beginnings of a fairly well rounded skill set.
Phil
led pad
