Old 12-13-2012, 09:41 PM   #11
TURBS's Avatar
Then a few things.
1 fuse protection on converter is blown.
2 circuit breaker to battery is tripped or bad.
3 converter is smoked.
If it's a wfco converter there's a trouble shooting guide in the "files" section on upper left hand of frf web page in the green.
Select the file with your model number then trouble shoot away.
Turbs
Old 12-13-2012, 09:49 PM   #12
Dave_Monica's Avatar
Originally Posted by TMULVANEY23 View Post
Yes. If I disconnect the battery it will hold a charge forever.
If the converter checks out but the battery is losing voltage while on shorepower, I only thing I can think of is a short to ground somewhere on the 12V side.
Dave
Old 12-13-2012, 11:01 PM   #13
Herk7769's Avatar
This sounds like the frame fuse from the battery to the converter is open.
Find the fuse.
Press the tiny button on the side and see if it clicks in.
If so everything should work properly again.
Everything powered by pigtail is working, but power from the battery is not getting to or from the converter.
ID:	22289   Click image for larger version
ID:	22290   Click image for larger version
HAM CALLSIGN - KC3FFW
Old 12-14-2012, 06:08 PM   #14
Thank you everyone. I am back in action! The reset under the camper was the answer. All your suggestions lead me to finding the answer. Thanks again and have a Merry Christmas!
Home is where you park it!
2010 Grey Wolf
TMULVANEY23 is offline   Reply With Quote
Old 12-14-2012, 06:18 PM   #15
TURBS's Avatar
Saweet SOLVED!
battery, electrical
