When I am hooked up to 120vt everything works however my battery looses it's charge over time. When not hooked up to 120vts the battery system does not work inside the camper. All the outside functions like slide, stabilizers, and awning work. Any one have a clue what might be going on?
Thanks,
Home is where you park it!
2010 Grey Wolf
It can be one of two things...the battery is done and won't hold a charge or the camper's converter isn't charging the battery when plugged into shorepower. If you have a voltage tester, the converter should be putting out at least 13.5V at the battery if it's working correctly. A fully charged battery should read around 12.6V when not plugged into shorepower. If the converter checks out, you could take the battery to as auto parts store and have it load tested to be sure.
I will check the converter. The battery checks out OK. Would this be the case with the lack of battery power inside the camper? I thought the converter was working since everything works on shorepower.
2010 Grey Wolf
1 fuse protection on converter is blown.
2 circuit breaker to battery is tripped or bad.
3 converter is smoked.
If it's a wfco converter there's a trouble shooting guide in the "files" section on upper left hand of frf web page in the green.
Select the file with your model number then trouble shoot away.
Yes. If I disconnect the battery it will hold a charge forever.
If the converter checks out but the battery is losing voltage while on shorepower, I only thing I can think of is a short to ground somewhere on the 12V side.
Thank you everyone. I am back in action! The reset under the camper was the answer. All your suggestions lead me to finding the answer. Thanks again and have a Merry Christmas!
2010 Grey Wolf
