Old 05-17-2015, 01:41 PM   #11
2012 Solera
Good to check the easy stuff first - confirm the breaker isn't tripped and see if the converter is working, as noted above.
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 05-17-2015, 08:43 PM   #12
fonzie's Avatar
Originally Posted by mckirby50 View Post
Also I'm not seeing the mini- breakers in the lower left hand corner of my photo
You have two of those mini-breaker, try to re-set by pressing black button...
Fonzie
Old 05-17-2015, 09:07 PM   #13
Where might I find this elusive WFCC T-30 converter ?
I have not even found the 40 amp fuses!!
I have a installation manual for WF 9800 Series Power Center but haven't found it either! Looks like the fuses are on the back of that, correct?
The converter is mounted on the refrigerator wall, with access through the under bed panel. There is a mod posted, that opens up the right side panel when opening the outside main storage bay door. I had modified the original posters cover panel. It really allows greater acess to the various components under the bed.
electric, electrical
