Old 06-08-2018, 06:31 PM   #21
Originally Posted by canuckKamper View Post
Here is my panel. I have followed everyone’s ideas and I’m pretty damn sure it’s the converter. Volt meter only reads 5.5v when I’m hooked up to shore power. I fully recharged my battery hooked it back up and volt meter reads 13.6 on the converter when hooked to shore power. I can’t find a reset switch anywhere in the A frame.
Are those 2 red fuses side by side, that appear to be 40 amp, good fuses?
If your battery is reading 13.6 back to the converter that only had 5.5 before, then your resettable fuse is good. Remove the #6 red wire and white wires from the converter that comes from the battery then read the voltage on the converter.
Old 06-08-2018, 06:36 PM   #22
World Wide Wanderer
wahoonc's Avatar
Back in post 5 I gave you a link to the WFCO trouble shooting documents. Follow them step by step and you will have your answer.
Aaron [emoji41]
Aaron & Rhonda
wahoonc & Airangel60
2016 Coachmen Concord 300DS
2015 Fusion Hybrid following along
wahoonc is offline   Reply With Quote
Old 06-08-2018, 06:50 PM   #23
Originally Posted by MR.M View Post
do all your lights work when on shore power when battery is disconnected ? the converter S/B behind the distribution panel you need to check it from the converter with battery disconnected . there are fuses in the converter it's self . did you follow the battery wires up front . it does go to a re-setable fuse follow the wires till you find it
With battery disconnected I have no lights. Only the gas detector has a red light on. I’ve followed the wires all the way to the front and look everywhere and there is no re set table fuse
canuckKamper is offline   Reply With Quote
Old 06-08-2018, 06:54 PM   #24
find the converter circuit breaker and turn it off then on. Again, did the two 40 amp side by side fuses check ok? What was the voltage one the converter with the wires disconnected?
Old 06-08-2018, 06:55 PM   #25
Instead taking to wires off I disconnected the battery simply because I can’t find my Allen key to do it. Anyways it’s reading 7.7v
Old 06-08-2018, 07:00 PM   #26
Looks like you are correct. a bad converter.
Old 06-08-2018, 07:04 PM   #27
Ok so what is a good replacement for it. I can get the one pictured for free if it’ll work
Old 06-08-2018, 07:13 PM   #28
I'm gonna defer to others to answer that one.
Old 06-08-2018, 07:35 PM   #29
World Wide Wanderer
wahoonc's Avatar
Your current one is a 55 amp, the free one is a 45 amp. Personally I would upgrade to the equivalent Progressive Dynamics 55 amp.
Aaron [emoji41]
Aaron & Rhonda
electric, electrical
