Old 07-27-2013, 07:59 PM   #41
Originally Posted by f1100turbo View Post
Then can be all rusty and getting no power through as well.
Attachment 36281
There are two of these (25 amp written on the side), not resettable, on top of the battery connected to the positive post. They look to be in good condition.
Lesley.
Lesley is offline   Reply With Quote
Old 07-27-2013, 08:08 PM   #42
TURBS's Avatar
Lesley.
Check to see if you have 12v on both posts of each breaker.
Turbs
Old 07-27-2013, 10:30 PM   #43
Turbs
I will do that. Thank you. Lesley.
Old 07-27-2013, 11:17 PM   #44
Turbs
I just bought a multimeter and now I will have to learn how to use it.
Lesley.
Old 07-28-2013, 08:30 AM   #45
VinceU's Avatar
Set your meter to measure 25 volts DC- place the black negative probe to a clean area of the frame (-) and the red probe to each side of the fuse/circuit brk. Measure the side attached to the battery first, then the protected side. They shoud each measure 12-13 volts DC.
Old 07-29-2013, 12:00 PM   #46
The battery itself is testing at 12.33V. The 2 small rectangular fuses attached to the + post of the battery are reading 0. When I replace these, do I need to disconnect the battery?
I did replace the 30 amp fuse that is about 18" from the battery as it was blown.
Thank you, Lesley.
ID:	36439   Click image for larger version
Old 07-29-2013, 12:34 PM   #47
TURBS's Avatar
Thank you, Lesley.
Probably don't need to but I would.
Turbs
Old 07-29-2013, 05:04 PM   #48
VinceU's Avatar
Thank you, Lesley.
Interesting arrangement. The bottom CB is connected in parallel to the top, but only the top side is used for load. The bottom is used as a buss bar but even if it opened nothing would change. You really only need to concentrate on the top brk with the wire attached. Connect your meter to (-) and the red lead to that circuit breaker both sides. You should have battery voltage on both terminals. Not sure why all the buss bars and two fuses, only one load coming from the lot! Good pics. BTW. The two leads to the left are unfused. Wiring may not be original.
Old 07-29-2013, 06:36 PM   #49
Herk7769's Avatar
I looked twice at that myself. I think the person who installed that arrangement did not have the correct fuses; but had a drawer full of the others. By paralleling them, the load across is shared equally (if they are the same size) and if one blew, the overload would certainly take out the other.
HAM CALLSIGN - KC3FFW
Old 07-29-2013, 10:29 PM   #50
Is it possible to replace the two 25 amp circuit breakers with one 50 amp circuit breaker or should I keep it the way it is? By the way, the trailer is wired for 15 amps. I don't know if that makes a difference.
Lesley.
