Old 07-30-2013, 01:51 PM   #51
Today I bought two 30 amp circuit breakers to replace the two 25 amp that were being used. I could not find 25 amp...only 30. Do you think that will be okay?
Lesley.
Lesley is offline   Reply With Quote
Old 07-30-2013, 02:07 PM   #52
Herk7769's Avatar
Lesley.
You really need one 50 (if there were 2 25s prior) or 2 20 amps.
I would NOT go up in amperage without knowing what is on them.
HAM CALLSIGN - KC3FFW
Old 07-30-2013, 02:47 PM   #53
I will try one 50 amp breaker. Hope this solves the problem. Will let you know.
Old 07-30-2013, 09:06 PM   #54
VinceU's Avatar
Good point, my popup had a water pump and some lights. What does this popup up have to require 50 amp service?
Old 07-30-2013, 09:27 PM   #55
There is a water pump, lights, refrigerator, ceiling fan, heater fan...the usual things. So, two 20 amp circuit breakers should be okay. I am not able to find the 25 amp CBs. The original owner had an a/c unit installed on the roof, but that runs off the ac current only, of course.
Thank you for all your help. I will let you know if this solves the problem.
Old 08-01-2013, 11:12 AM   #56
I replaced the circuit breaker near the positive battery post and still no power to the inside lights. I finally contacted Forest River and was able to narrow it down to a wiring problem on the battery. The large white wire was connected to the positive post and should have been on the negative post. I changed it this morning and all seems to be working fine now. I feel great and now ready to go camping with everything working.
Thanks to all of you for your time and help. This is a wonderful site.
Old 08-01-2013, 11:19 AM   #57
TURBS's Avatar
If the battery was hooked up backwards then it should have blown the converter protection fuses.
If there still blown the converter isn't working.
Turbs
Old 08-01-2013, 11:21 AM   #58
TURBS's Avatar
Also in your picture I see the white to positive!
I can't believe none of us noticed!
Old 08-01-2013, 11:26 AM   #59
Well, I have replaced all the fuses and everything is working fine now.
Thanks again. I do appreciate the help.
