Old 06-07-2016, 08:00 PM   #1
Electrical question
I have a 2015 saq365. I want to install a Fan-Tastic fan in the front bedroom. The unit came pre wired for a 2nd AC, I took the decorative cover of the ceiling vent, I found the outlet for the ac along with the thermostat wires. I dug as deep as I could but I can't find a 12 volt source for a Fantastic Fan. I'm not sure if I should pull 12 volts off the ceiling lights, If that wiring is heavy enough. I don't want a overload. Any input is very helpful. Thanks
mrwoodmin is offline   Reply With Quote
Old 06-07-2016, 08:13 PM   #2
Lots of have people posted that they've used the closest light.
Another alternative is to find the other end of the thermostat wiring, hook it up to 12 VDC somehow and use that.
2011 Traverse LT, 3.6L, FWD
Old 06-07-2016, 08:30 PM   #3
Is there a thermostat already prewired for the optional AC ?
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
Boon Docking 99% of the time.
2009 F150 - 5.4 Litre - Tow Package
boondocking is offline   Reply With Quote
Old 06-07-2016, 08:41 PM   #4
Yes there is, The 120 outlet, thermostat wire and temp sensor wire. It,s actually tied into the main thermostat with 2 zones
Old 06-07-2016, 09:01 PM   #5
TURBS's Avatar
Electrical question
I'd spend the $700.00 and just put an a/c unit up there.
Your a 1/4 the way there buying a fantastic fan!
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
2016 nights camped "10"
Old 06-07-2016, 09:03 PM   #6
So you could probably disconnect those wires from the main thermostat and tie them into the 12VDC and ground that supplies the thermostat, if yours works that way. (My Coleman Mach t-stat has both a 12VDC and a ground wire.) Then just wire the fan to the ends at the roof vent.
I haven't read it all, but here's a similar thread going on right now:
Bedroom vent wired for fan?
Old 06-08-2016, 12:08 PM   #7
Head Rambler
I have to agree with Turbs. I'd spend the extra few dollars and go ahead with the A/C.
Gotta go campin!
electric, electrical
