Old 07-05-2016, 07:25 AM   #1
electrical question
can someone tell me or have a diagram for this? It's under tongue on 12
wolf pack27
Ferg1 is offline   Reply With Quote
Old 07-05-2016, 08:36 AM   #2
Head Rambler
Those are resettable fuses. They're kinda like circuit breakers. If they're manually resettable they'll have a small button on one end.
The picture doesn't show where the wires go, but the end with the metal bar jumper should be the battery end (most likely the big red cable) and the other ends go to other equipment (converter, jacks, etc.).
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
Old 07-05-2016, 08:56 AM   #3
thanks, any ideal what the relay feeds, the green wire from fuse to relay was unhooked,
Old 07-05-2016, 10:18 AM   #4
Head Rambler
I can't tell which wire is hooked to which terminal, but it's most likely for landing gear or such.
Do you have a remote for the RV equipment?
Gotta go campin!
Old 07-05-2016, 10:24 AM   #5
no remotes, i'll look tonight and check if it goes to tongue jack, just noticed it last night when i got home. the break away cable was gone after hitting tire recap, but what worries me was the trailer breaks didnt activate, got to do checking before we go back out. i assume the break away switch get power from main trailer battery not like my car trailer and has one built into switch.
Old 07-05-2016, 10:45 AM   #6
Head Rambler
That could be for the breakaway, but it's odd that they put a relay in the circuit.
I'd be concerned that they didn't activate as well. It could have snapped the cable off the pin and the pin (or part of it) may still be in there.
Gotta go campin!
Old 07-05-2016, 10:47 AM   #7
it could have. i'll check it out THANKS
Old 07-06-2016, 10:40 AM   #8
after looking the breakaway switch is bad, no connection after plug was out, the green wire feeds the waste water blanket heaters, Rambler, Thanks for you help
Old 07-06-2016, 11:13 AM   #9
Head Rambler
Thanks for coming back and letting us know what you found. Especially about the relay being for the tank heaters. And about the breakaway switch too.
It'd be a good idea for everyone to periodically pull test the breakaway switch to make sure it works properly.
Gotta go campin!
Old 07-06-2016, 11:16 AM   #10
yea, it would, nevr thought of doing it before now
electric, electrical
