04-04-2018, 09:38 PM
Electrical question 12v lights
Recently had a new entry door installed on my 5th wheel. The old door had a small thin strip light that went along the bottom on the inside. I just noticed that the light is not on the new one. The installer cut the power wires and taped the ends. The wires stick out about a half an inch near the inside bottom corner of the new door. I checked them and they are live (hot). Some how I need to add a connector. I would like to wire 8 small marker lights to it. I don't know how much power each light draws. All I can find is 0.2w. Nothing about amps. Wondered if splicing 8 wires into one on both would be possible. What information do I need to find out?
04-04-2018, 09:48 PM
Are you sure about the .2 watts? Even if that is per light you are only .13 amps so that would not be an issue.
The .2 watts seems very low unless the are just LED indicator lights
2024 Artic Fox 3018 5th Wheel
Grand Design 2800BH TT 2021 - for sale
Prior TT 2017 Flagstaff 831CLBSS Classic Ultra lite - SOLD 5/21
TV 2024 F350 DRW - on order
Prior TV 2017 F150 6.5' bed 3.5 Eco-boost Max tow 1800lbs payload
04-04-2018, 09:51 PM
Yes they are small marker lights. Want to install them on the Lippert solid steps so they aren't tripped over at night and to mark each step in the dark
04-04-2018, 09:52 PM
The 0.2 w was on the description on them
04-04-2018, 09:56 PM
.2 watts at 12 volts is less than 20 milliamps.
2017 Rockwood 2703WS - Sold
2015 Keystone Sprinter 333FWFLS
2017 F250, 6.2 Gas, 3.73 Axle, 2902 lb Payload
If women don't find you handsome, at least they should find you handy!
04-04-2018, 09:58 PM
You should be good current wise. Are these 12volt lights or individual LEDs like from an electronic supplier? If individual you will need to add current limiting resistors, if 12 volt LEDs then it is built in
04-04-2018, 10:00 PM
So I should be good to connect all 8 lights to the two wires that ran to the previous strip light? Not all that knowledgeable on amps, milliamps, watts and such.
04-04-2018, 10:03 PM
12 v lights (partsam LED marker). I think I might have missed read it. Found another description says 1.2w . Each light has 6 led bulbs and each bulb is 0.2w. These lights are really small
04-04-2018, 10:28 PM
You should still be under 1 amp.
04-04-2018, 10:30 PM
How do I know the capability of the wire that supplies the current?
04-04-2018, 10:38 PM
If you have a wire stripper, you can use it to measure the wire gauge and check online to see how much current that size wire will carry.
04-04-2018, 10:39 PM
Ok. Thanks
04-04-2018, 10:49 PM
If it’s 22 awg or bigger, it will carry at least 1 amp.
04-05-2018, 02:48 PM
Electrical problem
You can use Ohm's law of power to get the amperage. if you are wiring in series just add to get the total wattage . Then divide the wattage by 12 volts and you will have the amp draw. if you are wiring in parallel the math becomes a little more in depth ie p1+p2+p3 divided by p1xp2xp3 that gives you the total watts. divide that by 12 volts and you have the amperage.
04-05-2018, 03:16 PM
Just splicing wire from lights (about 6-8" long) into a main wire
04-05-2018, 03:25 PM
It might be easier to simply use a short direct connect (no controller) LED strip. Simple two wire connection and stick on.
Similar to this:
https://www.amazon.com/Waterproof-St...inch+led+strip
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
04-05-2018, 04:43 PM
My trailer uses a single amber-lensed light under the steps for backlight. I think your idea of using amber side markers will work well. However, I wonder if 8 lights will be too bright. It might be best to consider just 4 or fewer to start. In any event, the LED markers will not draw too much current for your wiring.
Please share a picture when you are finished. I'm sure many of us would like to see how well your idea worked.
2015 Wildcat 282 RKX
2011 F350 Lariat, 6.7 L. Diesel, 8 ft., SRW, Reese R20
04-05-2018, 04:49 PM
Will be glad to post pictures when done. Mainly lights will be for steps at night. They are small and low wattage. I want to illuminate the steps at night. My wife takes our old mini schnauzer out a couple of times during the night. I just want her to be able to see each step. I don't want the main outside light on the camper on as it is big and very bright. That way we don't disturb the campers in the next site over while they are trying to sleep. I will take your advice however and power them all up in the dark to see how bright they are.
