Old 02-21-2014, 04:22 PM   #21
davel1971's Avatar
oh, that type. Those sockets can go bad due to spring and plate internally that make contact.
David & Lynn
Old 02-21-2014, 04:23 PM   #22
fonzie's Avatar
OK these bulbs are 12 volts, but maybe the wrong ones. Look inside your light fixture, is there two contacts are just one?
Fonzie
Old 02-21-2014, 04:24 PM   #23
Being the dummy I am, the number on the replacement bulb is different from the original, that may be a something, but still don't understand how both burned out at same time???
YogiBear is offline   Reply With Quote
Old 02-21-2014, 04:25 PM   #24
2 contact points
Old 02-21-2014, 04:28 PM   #25
davel1971's Avatar
some are interchangeable, just different watts so different numbers. As long as same number of contacts
David & Lynn
Old 02-21-2014, 04:28 PM   #26
Stupid me replacement bulbs only have one contact point!!! Holy smokes that will never work, and probably the problem after driving u guys nuts trying to help. I will go back to Rv dealer and see if the correct bulbs. The single point would cause a dead short right off. Wow I can be so silly some times. Thanks to all for asking me the right questions
Old 02-21-2014, 04:32 PM   #27
davel1971's Avatar
go to a Walmart or auto parts store. Will be cheaper than RV dealer
David & Lynn
Old 02-21-2014, 04:33 PM   #28
fonzie's Avatar
Fonzie
Old 02-21-2014, 04:35 PM   #29
Todouble's Avatar
Glad you found the prob!
Todouble is offline   Reply With Quote
Old 02-21-2014, 04:50 PM   #30
Herk7769's Avatar
Ditto!
HAM CALLSIGN - KC3FFW
electric, electrical
