Old 08-12-2016, 01:47 PM   #1
Old car's Avatar
Electrical schematics
Are electrical schematics available for particular travel trailer models? It would be nice to have one available in case issues were to arise.
Randy and Patty
2015 Sabre 33 CKTS-6 Platinum Edition
Reese 16K Slider hitch
2014 Ram 2500HD Crew Cab 6.7 Cummins Diesel
Old car is offline   Reply With Quote
Old 08-12-2016, 01:49 PM   #2
Weekender
Ford1's Avatar
Dreamer!!!!
Ford1 is offline   Reply With Quote
Old 08-12-2016, 02:01 PM   #3
Moderators' Assistant
bikendan's Avatar
Only ones I've seen are for a few of the higher end RVs.
Dan-Retired Firefighter/EMT
2016 PrimeTime TracerAIR 255, pushing an '07 Chevy Avalanche
Equalizer WDH and Prodigy BC
Old 08-12-2016, 02:03 PM   #4
wmtire's Avatar
They don't seem to be readily and easily available, but you may be able to contact your particular RV division and see if they can accommodate.
2011 Flagstaff 831 RLBSS
I've invented a new word. "Plagiarism"
Old 08-12-2016, 02:08 PM   #5
dieselguy's Avatar
You'll never find two of the same model units wired the same ... knowing that ... FR doesn't put effort in any diagrams available to John Q. Public. Most SOB's ride in the same canoe.
dieselguy is online now   Reply With Quote
Old 08-12-2016, 02:12 PM   #6
wmtire's Avatar
If you will look in the FRF library, we do have a few schematics of various RV's that the members were able to get from Forest River and share here.
It's most likely going to depend on the particular division, and if such exists.
Old 08-15-2016, 04:14 PM   #7
Access to wiring
Since it appears that there are no schematics for any? trailers, does anyone know if the wiring runs through the walls, ceiling or floor? my GFI outlets dont work, they did but after not using our wildwood 23fbl for 2 years they dont work, I checked the breaker and all is well 110v in and out,no 110 at bathroom our kitchen outlet, in the manual its says something about an inverter switch.. I do not have one of these.. I've used our 1.8kw coleman generator numerous times before with no issue. any advise? also the 3 speed fan over the bed doesnt get power. No sign of mice living in or around trailer, ants though are a problem
This is my first post so thank you everyone for reading
Tony
Tony_agr is offline   Reply With Quote
Old 08-15-2016, 06:01 PM   #8
Head Rambler
They run the wiring wherever it's convenient. So yes, they are run in all the aforementioned places.
Have you tripped and reset all the breakers?
Have you tested all the fuses?
Have you went all around and through the RV looking for GFI receptacles? They can put them in some strange places.
There have been reports of the wiring coming loose in the back of the receptacles causing the remaining receptacles to be dead. But, before pulling all the receptacles out make sure you check all the easy things first.
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
electric, electrical
