Old 06-29-2015, 07:15 AM   #11
I have noticed a lot of reverse polarity talk lately. Just curious, how many of you are actual electricians? To tell someone to just flip the wires around without trouble shooting and knowing the actual cause could possible cause some issues.
harderd is offline   Reply With Quote
Old 06-29-2015, 07:18 AM   #12
Originally Posted by wmtire View Post
It's possible you were plugged into a faulty/miswired outlet at the campground.
I'll send a message to Mike Sokol on your behalf, who is our go-to person on RV hot skin condition that you're referring to. He is a member here, and also has many informative videos and such on this. You won't meet a better person trying to save everyone's live's.
Here is a link to his website and things to consider to see if it applies to your situation:
RV Electrical Safety: Part IV – Hot Skin | No~Shock~Zone
Good information
Old 06-29-2015, 08:45 AM   #13
Originally Posted by Yarome View Post
Reverse polarity. If your plugged into shore power, your outlet needs to be rewired. If you're on battery then go flip flop the battery cables.
This is Mike Sokol from the no~Shock~Zone and I just received a private message from the forum moderator that I was needed here, sort of like the Batman Signal, I guess....
OK, let's get to the bottom of this quickly, since this is a simple thing. But first, let me detail what is is NOT!!!
It's NOT reversed or flipped battery cables. And you certainly don't want to be swapping battery cables at any time since that really DOES reverse polarity and could easily destroy electronics such as your inverters, televisions, stereo systems, etc... That's because a battery has a positive and a negative pole, so reversing the cables actually reverses the polarity, and electronics are VERY sensitive to polarity reversal and can be destroyed by in in a few milliseconds (a millisecond is 1/1000 of a second).
It's NOT reversed polarity on the AC shore power plug, unless something else is miswired at the same time. That's loosely defined as the Hot and Neutral wires being swapped or "reversed" in the extension cord or outlet. But the White Neutral wire is supposed to be isolated from the frame/skin of your RV according to the NEC and RVIA build codes. If you've accidentally bonded (connected) the Neutral and Chassis Ground together, then it's possible that a Reversed Polarity Outlet could energize the RV chassis/skin, but if the ground wires is intact it should trip the circuit breaker immediately.
It's definitely some sort of compromised EGC (Equipment Grounding Conductor) more commonly called a safety ground, or simply "ground" by most consumers. This "ground" is supposed to drain away any small ground fault currents and trip a circuit breaker for any large ground fault currents.
By definition, a ground fault current is any sort of leakage between the incoming hot wires and the chassis of an appliance or your RV itself. There will ALWAYS be some ground fault current available in ANYTHING plugged into a power outlet, but it's normally very small, typically less than 1 mA (1 milliamp or 1/1000 of an ampere). Most of the time there will be a balancing act between the hot and neutral leakage impedance which the open ground hot-skin voltage biasing to around 1/2 of the line voltage. So if your EGC (ground) wire is compromised without anything else being wrong in your RV, you'll often measure 40 to 80 volts between the RV frame and a screwdriver stuck in the earth. While this sort of low-current ground fault may not be immediately deadly, you still need to take it seriously since it can turn into a high current ground fault in a heartbeat, and there will be nothing to stop it from killing you or a loved one.
OK, now let's consider what can compromise your RV's grounding system. There needs to be a solid connection between the frame/chassis of your RV all the way back to the electrical service panel feeding your home or the campground. So everywhere there's a connection, it's possible for a failure to occur. So that means that it could be caused a broken or loose or corroded connection in your shore power cable, extension cord, dog-bone adapter, pedestal outlet, or even the AC power feeding the pedestal or outlet itself. I've seen loose grounding screws inside of the RV's circuit breaker box cause this, and even a broken ground screw on the back of the RV's shore power jack on the side of vehicle. To be code compliant, this EGC (ground) needs to have less than 1 ohm impedance back to the service panel's G-N-E bonding point.
Also, a ground rod connected to the frame of your RV does NOT "ground" your RV. Lot's of reasons for this, but an earthed ground rod can often measure up to 100 ohms to the earth, so while it might drain away a low-current ground fault, it certainly CAN'T drain away a high-current ground fault. That can be caused by a screw being driven though a wire in the wall, or insulation worn through by rubbing on the frame, or even a failed transformer in your microwave oven. As a side note, jacks on the ground do nothing to "ground" your RV, so don't get me started on that subject.
Finally, there's one really dangerous outlet miswinrg condition I sometimes find in old garages and church outlets. I call it an RPBG (Reverse Polarity Bootleg Ground) and it can't be detected by any standard tests including 3-outlet testers or even metering between H-N, H-G and N-G. You must have an external reference to earth to find it. See my article on it at Failures in Outlet Testing Exposed | Contractor content from Electrical Construction & Maintenance (EC&M) Magazine and my video on how you can use a NCVT (Non Contact Voltage Tester) to easily find a hot-skin condition at So, please take any felt shocks as a sign that something is seriously wrong with your RV's ground system, which could be anywhere from the outlet itself, dog-bone adapter, extension cord, shore power cord, or even the ground bonding point inside your RV itself. I get all the police and inspector reports whenever someone is electrocuted (killed) by an RV or guitar on stage, and most every instance was preceded by someone noticing they were feeling a shock for a few days or even weeks. Modern code requires that RVs and appliances are designed so that you NEVER feel a shock. If you do, then the grounding system has failed. It's as simple as that.
Also, at the risk of self promoting, I think that all of you, especially the ones who are giving out incorrect electrical advice, need to get and read a copy of my book - No~Shock~Zone RV Electrical Safety. This is a must-read before doing any electrical work on your RV, and will certainly give you enough information to discuss electrical problems with a trained technician or licensed electrician.
ATTN MODERATOR - Feel free to delete the book info above if that violates forum self-promotion policy. But I think that everyone who plugs an RV into an electrical outlet needs to understand the basics of electricity for their own safety.
Let's play safe out there...
Mike Sokol
No Shock Zone
jmsokol is offline   Reply With Quote
Old 06-29-2015, 09:08 AM   #14
wmtire's Avatar
Mike Sokol
No Shock Zone
I think we can make an exception here for this Mike. We do agree that this can be a life-threatening situation, and it is in the best interest of our entire membership for everyone to learn as much as they can about this.
Signed
Commissioner Gordon
2011 Flagstaff 831 RLBSS
Ive lost my scapegoat.
Old 06-29-2015, 10:17 AM   #15
This is great information.
Old 06-29-2015, 02:57 PM   #16
Thanks.... Is my explanation of what causes an RV hot-skin condition clear enough for everybody?
Old 06-29-2015, 03:02 PM   #17
Flybob's Avatar
DO NOT flip battery cables.
I have seen this situation occur in RVs that have burned out WH elements as a result of turning on WH ( electric ) with an empty WH.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 06-29-2015, 06:31 PM   #18
This is interesting.
50 Amp Outlet Tester
Old 06-29-2015, 07:14 PM   #19
I think some folks need to chill just a bit..
If you read everything there were 2 other areas as well mentioned to possibly troubleshoot with possible solutions if for no other reason than to rule out something hinky at any power source.
Maybe it's wrong of me to assume that any reasonable person would do a little troubleshooting in that area before implementing any kind of fix, and don't necessarily need a step by step guide to do so. If they need additional help with troubleshooting a specific area, they are always welcome to ask for additional information.
Kept in the context that's been implied, I guess I was telling him to go rewire his 110v source, flip the battery cables and the output wiring of his converter.. sight unseen.
I learned something new, Thank you Mike, and won't perpetuate the myth.
rana is offline   Reply With Quote
Old 06-29-2015, 07:18 PM   #20
just curious, how many of you are actual electricians? To tell someone to just flip the wires around without trouble shooting
I never meant to imply he should flip his cables without troubleshooting, but you're right... I'm not a licensed electrician and will refrain from making any additional comments with regard to RV power systems in the future.
