05-15-2017, 12:47 PM
Emergency brake switch
Went camping this week, I forgot to disconnect cable to the emergency brake switch, the pin was pulled out of switch. I did not notice for 4 days.
Switch was very hot, put pin back in and it cooled right down. The trailer brakes seem to be working ok. My trailer battery will not charge, assume it was damaged by the switch. Could you please let me know what ALL could be damaged by the pin being out of the switch for that period of time? Wondering if charging system or inverter was damaged? Thanks
05-15-2017, 01:03 PM
Battery could be permanently damaged.
Maybe some brake damage.
The CONverter (not INverter)should be fine.
05-16-2017, 09:55 AM
Another noob question here -- pulling that pin draws current or causes brake damage?
Cottonwood Heights, Utah
2016 Evo by Forest River T2050 (23')
2014 Toyota Tundra 5.7L V8
Days camped in 2017: 53 (so far!)
05-16-2017, 10:03 AM
Yep, pulling the pin activates the switch that applies current to your electric brakes. So your brakes were applied until the battery discharged or the pin was reinserted. Might have your brakes and battery looked at.
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
05-16-2017, 10:30 AM
It's only been a couple of days and while on shore power. I'm therefore not too worried about it, but I won't be doing that again.
05-16-2017, 10:35 AM
Could be both.
For sure it definitely draws current as the break-away switch activates the circuit (by pulling the pin) to apply the electric trailer brakes in a emergency situation.
Because the brakes are applied using an electro-magnet, there could be damage to the electro-magnet itself (overheating) that could have caused damage to it.
05-16-2017, 10:38 AM
Yep, 5picker is right. Better safe than sorry. Do some research and you will find lots of instances where wiring or magnets melted, especially if it's been several days and your battery is dead.
05-16-2017, 10:41 AM
Several things could have happened even if 'only a couple of days.'
One your converter was working overtime to keep up with the demand of the current draw of the brake system. It may or may not have been able to do so.
Two, (and because of one) your battery may have went to a low voltage state.
Hopefully it will recharge and hold a charge.
Three see my post above about overheating the electro-magnets.
They can be damaged in hours let alone days if left on full time.
But then again, depending on the amount of current draw available, ambient temps and so forth, they may not be damaged at all.
05-16-2017, 10:44 AM
I was actually working on the trailer both days. It never went below 13.46 volts.
05-16-2017, 10:47 AM
So why did you say it won't charge? Very confusing. But several folks have given advice. Take it or leave it.
Enjoy the rest of your trip!
05-16-2017, 10:52 AM
The member you are replying to, is not the OP who made that statement.
2011 Flagstaff 831 RLBSS
05-16-2017, 11:00 AM
Ah, my bad... Just saw both names started with an 'f'.
05-16-2017, 11:09 AM
It killed my battery, will not hold a charge. Brakes seem to be working though. Any way to check each magnet in each wheel?
05-16-2017, 11:10 AM
since the switch was hot and cooled down when put back in that tells me at least some of the magnets are ok and the battery wasn't dead at that time. I would stil check the magnets as some may be bad
Could be a fuse between the converter and the battery, can you try a separate battery charger directly on the battery. If you have a voltmeter how low did the battery voltage get?
2024 Artic Fox 3018 5th Wheel
Grand Design 2800BH TT 2021 - for sale
Prior TT 2017 Flagstaff 831CLBSS Classic Ultra lite - SOLD 5/21
TV 2024 F350 DRW - on order
Prior TV 2017 F150 6.5' bed 3.5 Eco-boost Max tow 1800lbs payload
05-16-2017, 11:13 AM
One other thing has me confused, the breaker for the washer outlet tripped and will not reset. Nothing was ever plugged into the washer outlet. Could that have been caused by the brake switch or is it just a fluke in happened on same trip?
05-16-2017, 11:19 AM
I assume any washer would be 110V AC, absolutely no connection to any issues on the 12V DC side which includes the brakes
05-16-2017, 11:46 AM
We're two different people. I just glommed onto the thread with a question.
05-16-2017, 12:57 PM
No problem, I wasn't paying close enough attention before I shot my mouth off
05-16-2017, 04:40 PM
2007 Surveyor SV230 - 200 Watts Solar/MPPT Controller - 220 AH Battery Bank (Two-GC2) - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
2009 F150 - 5.4 Litre with Tow Package
Boon Docking 99% of the time.
05-16-2017, 05:06 PM
Check the two large current fuses (30-40 amps) in the fuse panel. They are there to protect against mis-connecting the battery, but if you draw a significant amount of power for long enough, they could blow. You brakes are designed to be applied to stop and sit at a light or toll, not be on full for 4 days. The magnets get hot and can be damaged. I would check each one carefully. If the battery is indeed dead, you should have it load tested. A damaged battery will appear to charge, but will not support a load for any length of time.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
