Old 06-30-2016, 07:44 PM   #1
JohnF's Avatar
EMS Clicking
Tonight I thought I would try a dry run on using my Honda Inverter generator EU300IS to power my 5th wheel camper. We plan on doing some boon docking in the near future and I wanted to see what it was capable of doing.
I also have a Progressive EMS-HW50c hardwired in. When i plugged into the generator, I was not getting power to the air conditioners and microwave. The EMS was showing an error of E2 which is an open ground. I turned the EMS off via the small switch on the remote monitor and everything started working.
My concern is that when the air conditioner kicks on there is a couple of seconds of clicking coming from (what I believe) is the EMS box under foot. Can anyone explain what is happening? I plan on calling Progressive in the morning.
John
Ohio
2016 Cedar Creek 36ckts
2015 Ford F-350
4WD SRW Diesel
JohnF is offline   Reply With Quote
Old 06-30-2016, 07:48 PM   #2
wmtire's Avatar
Read this article by Mike Sokol, as this is probably your problem, which is common with inverter type and small generators... as he discusses your generator and EMS in great detail.
Generator Ground-Neutral Bonding | No~Shock~Zone
Mike shows you how to fix the problem pretty simply.
Here is his youtube video on the same thing:
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 06-30-2016, 08:08 PM   #3
JohnF's Avatar
Thank you. Looks like a quick trip to the hardware store in the morning may correct my problem.
John
Ohio
2015 Ford F-350
4WD SRW Diesel
Old 06-30-2016, 08:12 PM   #4
wmtire's Avatar
You are welcome, and please make sure to thank Mike, as he is a member here (jmsokol) and an all around great person.
I think this will get you all lined out.
Old 07-01-2016, 07:02 AM   #5
JohnF's Avatar
That did the trick. Thanks all!
John
Ohio
2015 Ford F-350
4WD SRW Diesel
Old 07-01-2016, 07:31 AM   #6
John
Had to do the same thing to our Generator,the "No Shock Zone" sure knows his stuff! I don't know why the Genny MFG say "RV Ready" without "EMS" only,then they are Supplying Voltage with a "Open Ground"! Youroo!!
