Old 09-26-2014, 01:16 PM   #11
Name:	ImageUploadedByForest River Forums1411755277.132350.jpg
See the orange wire? That's the one you want.
Name:	ImageUploadedByForest River Forums1411755325.809950.jpg
Don't reverse input and output. It's easy to get confused after you take the cover off but when you put the cover on the labels are pretty much right over where it's corresponding wire enters the box.
2016 Flagstaff 27VRL with overloaded tires from factory
2015 Chevy Silverado
Paul GA is offline   Reply With Quote
Old 09-26-2014, 01:54 PM   #12
Thank you, will try tonight. so then does it protect AC/DC or just AC?
mike2246 is offline   Reply With Quote
Old 09-26-2014, 02:06 PM   #13
Just a/c. You don't normally hear about DC issues.
Old 09-26-2014, 07:38 PM   #14
You're looking for a 10/2 romex line. Color coding began around 2001 so yours should be orange. I had a cabinet next to my panel, and enough extra romex to put it there.
I used standoffs when I mounted it to the floor, the bottom of the case gets a bit warm.
Also, before you run your remote wire for the display, hook it up and make sure it works... My first data cable was bad, had to re-fish a new one thru the floor.
Old 10-14-2014, 04:14 PM   #15
Mike, how'd it turn out?
