Old 04-22-2013, 07:07 PM   #1
Phat Phrog Stunt Crew
awwall's Avatar
EMS-PT50C Reading High Voltage????
Need some help. My surge protector doing something strange. I have a 30amp service at home for my RV. I use a 30amp to 50amp dongle to supply power to the MH, works fine. Today, I hooked up my surge protector and got the following. L1 is reading 117v and L2 is reading 157volts. I have checked the dongle and have 122volts on each leg to the neutral as it should be. Ground is fine also, tried disconnecting at the panel and the EMS picked up an open ground, as it should. I will be calling Progressive in the morning, too late today.
Thought someone here might have some thoughts. Used the surge protector a couple of weeks ago at a park and it worked fine.
Wayne & Susan Biloxi,Ms
2012 GeorgeTown 351DS...2015 Ford Focus/Brake Buddy
FROG Member
awwall is offline   Reply With Quote
Old 04-23-2013, 06:35 AM   #2
treaves's Avatar
It's going to be either working, or not working. It's very unlikely that it's going to report an incorrect voltage, especially more than there actually is.
treaves is offline   Reply With Quote
Old 04-23-2013, 06:40 AM   #3
TURBS's Avatar
Subscribed.
Wanna see what u phind.
Turbs
Old 04-23-2013, 06:49 AM   #4
Dave_Monica's Avatar
Here's a link to the site and contact info... EMS-PT50C
I'm sure they answer your question.
Dave
Old 04-23-2013, 07:24 PM   #5
awwall's Avatar
No help on the phone, which I expected. It is in the capable hands of FedEx on its way to North Carolina. Lady was real nice on the phone and said they would either repair or replace it. Told me there is a 2 to 3 day turn around. They leave the device plugged in for 24hrs to insure proper operation. I just bought this unit in Sept 2012, so hope this is not a sign of things to come. These are supposed to be the best. Outlay was $15 for shipping.
FROG Member
Old 04-23-2013, 07:50 PM   #6
VinceU's Avatar
Did the unit trip on high voltage? The 30 amp provides only 120 on one leg, inside the adapter its a hybrid 120 volt to both the hot legs of the 50 amp supply to the coach. This problem sounds like a display electronic fault, if it really read 157 volts in the incoming circuits, I would think it would trip.
Old 04-23-2013, 08:08 PM   #7
awwall's Avatar
Vince, it did not trip, it would not come on line. When it saw the high voltage on L2 it would not close the internal relay and send power inside. Yep, I understand the way the adapter works, and that was the first thing I checked. I have a True RMS volt meter and it read 122.1 volts on both legs. The adapter was doing its thing. Funny thing is, I just used this at a campground about 2 weeks ago and had no problems. I wish I had the proper 240volt receptacle here at home to check it that way.
I hope they tell me what the problem is after repairing.
FROG Member
Old 04-23-2013, 08:19 PM   #8
"It was broke. Now it is fixed."
Old 04-23-2013, 09:46 PM   #9
awwall's Avatar
Good one Barry!!!
FROG Member
Old 04-30-2013, 07:31 PM   #10
awwall's Avatar
Update on unit. My EMS was shipped yesterday. Asked them what they had to do. Owner replied and said they had to replace the logic board and contactor. Was not surprised at the logic board, but was at the contactor. Re-asked if water got into it and here is the reply:
"This is always a problem with PT models no matter how hard you try to seal them some of the units just get this way"
This came to me directly from the President of Progressive industries. So here is the explanation of failure.
FROG Member
