Old 08-20-2013, 08:34 AM   #1
Everything dead inside 12 Volt
Hello
2013 Berkshire 390RB nothing works inside on the 12 v system.The batteries are charged and plugged in ,the generator doesnt work also unless i use the aux switch,As soon as i let go of the aux battery switch it dies what is going on.
Its like the batteries are not even connected yet all connections are tight and clean.
Greg
plootsa is offline   Reply With Quote
Old 08-20-2013, 08:58 AM   #2
Either the battery disconnect switch is turning it off (assuming you have one), or you've tripped an inline fuse/breaker. Those commonly looking this
and are usually found within a couple of feet of the battery.
Old 08-20-2013, 11:21 AM   #3
Open 150 Amp Fuse
I just found the 150 amp mega fuse open I think when I jumpered my engine from the house battery too much current opened it.
Thanks Greg
12 volt
