Old 12-19-2012, 10:05 PM   #1
crushor's Avatar
Extension Shore Power Cable
Not a trouble shooting question, however, due to the location of my trailer in reference to my home, I am using the factory shore power cable and an extension cable. This past year on our maiden voyage I packed the extension cable as I didn't know the distance from trailer to shore power at the CG. Didn't use it. How often (random question) do you find the need to use an extension shore power cable when at CG's?
2007 Ford F250 4x4 Harley-Davidson Powerstroke
2006 Cedar Creek Silverback - 35 LRLBS
(2012 -11) (2013 - 10 so far)
crushor is offline   Reply With Quote
Old 12-19-2012, 10:46 PM   #2
B47
Fortunately I have never yet had to use an extension shore power cord.
Old 12-19-2012, 10:54 PM   #3
Oklahoma Proud
MillerTime's Avatar
I never have either. I guess if I have a choice on parking close to electric or a water faucet I always chose electric. I guess that's why I have 125' of white hose
Old 12-19-2012, 10:55 PM   #4
GlacierGus's Avatar
I camped my way home after picking up my Mini Lite in Ohio (RVW). My third night out I camped at a CG where two units shared the electrical pedestal. My original cord was nowhere long enough. Luckily the CG loaned me an extension. I purchased my own extension now and will always have it along.
2013 Rockwood Mini Lite 2109S
2006 Dodge Durango Hemi 5.7
Equal-i-zer WDH
GlacierGus is offline   Reply With Quote
Old 12-19-2012, 11:02 PM   #5
Dave_Monica's Avatar
I carry a total of 100' of 30A cable and have had to use it all a few times. It's most common when camping in Ontario Provincial Parks to share a double pedestal between 2 adjacent sites. Once I had to position the camper so the 100" of cable would reach.
Dave
Old 12-19-2012, 11:02 PM   #6
So far, never had to use an extension at a campground but do carry a 75' when visiting some relatives so we can plug into their dryer outlet, of course we only get 30 amps but it works well if running only one a/c.
Sirsea is offline   Reply With Quote
Old 12-19-2012, 11:10 PM   #7
B47
Dave
Dave- I have a simple question regarding electrical power in Canada - that being is the power 60 cps or something other like the Euporean system?
Old 12-19-2012, 11:14 PM   #8
This has happened to us more times than I care to think about! The shared pedestal where if you are on the wrong side of the pedestal the RV cord is never long enough!! Than you need to run an extension underneath and across your site where everybody walks and walks on the cord to plug in. Who designs or wires these pedestals certainly doesn't understand RV's real well! There is only one application that I can think of where this might be acceptable and that is waterfront sites or view sites where Motorhomes use the side that doesn't work for Trailers. my rant, ok now I feel better.
Of all the things I've lost in my life the thing I miss the most is my mind!
prairiecamper is offline   Reply With Quote
Old 12-19-2012, 11:15 PM   #9
Canada is 60 cycle same as the US.
Dave
Old 12-20-2012, 04:39 AM   #10
Something Sirsea said could be dangerously misleading to the unwary. Sirsea didn't say so, but my guess is that his RV has a 50 amp, 240 volt shore line. Class C's and maybe some travel trailers use 30 amps, 120 volts. Plugging one of those into a dryer receptacle could be a disaster since the dryer receptacle is 30 amps, 240 volts. You could make up an adapter and be safe if the dryer receptacle is a newer 4-pin type (2 120 volt hots, neutral and ground legs), but the older 3-pin types don't have a ground leg. If you didn't get it right, you could get 240 volts into your 120 volt RV. Or, you may have 120 volts (from one hot leg and the neutral) but you would not have a ground.
I installed a TT-30 receptacle on a new 30 amp breaker at home, and use a 20 amp receptacle at my mother's house when we visit. I updated the wiring in her house a few years ago, so I know the circuit is truly 20 amps. In fact, I ran the wire when we added that section to the house when I was 15!
Back to the original post, I ran across a 50-foot "heavy duty 120 volt 20 amp" extension cord at Lowe's. It is 10 AWG so it is suitable for 30 amps. I cut off the ends and installed a TT-30 plug and receptacle. It cost a lot less than 50 feet of extension cord at the RV dealer. I have to use it at home to reach the new receptacle, and have used it at maybe 5% of our campsites.
