Old 09-01-2008, 06:42 PM   #1
steveqvs's Avatar
Extra Battery
I am thinking about putting an extra battery on my camper. Currently I have a year old one that is a Marine Battery. I only dry camp. I use a generator and during the week I am not there I use a solar panel. 5 watt. I really don't like to run the generator alot so I figure if I have 2 batteries I would have enough light time at night for the wife and kids. Also is there a way to rig charging the batteries. I have read that generators plugged in though the camper don't charge the batteries as efficiantly... is that correct?
thanks
steve
Seasonal site camping
steveqvs is offline   Reply With Quote
Old 09-01-2008, 09:14 PM   #2
Cyber Phrenologist
Radio's Avatar
I don't think your camper knows the difference between a generator and the grid provided the generator has sufficient output.
If you do go with two batteries be sure the batteries are identical, same rating, brand and batch numbers. Otherwise one may "load" the other and rob you of some of the capacity you should have in a two battery system
KU4OJ
Admin at www.openroadsradio.net, part of the Social Knowledge network.
"RVing and Amateur Radio served up on the same plate"
2008 (or is it 2009?) Rockwood 8280SS - 2007 F-150
Radio is offline   Reply With Quote
Old 09-01-2008, 09:37 PM   #3
steveqvs's Avatar
Thanks Radio,
But grid or generator they still go through my inverter in the camper to charge the battery right? The generator seems to charge my battery pretty quick but is that the best or most efficient way? So you are thinking I can't just add a battery to my year old setup? darn.
Old 09-02-2008, 06:42 AM   #4
Extra Battery
If you dry camp, the best setup are two six volt golf cart batteries. They will give you more amp hours than two 12 volt and last longer. Nevertheless, the above post is correct; you should use batteries of the same age; brand etc or you'll chance having one ruin the other. A 12 volt battery will draw power from the other (if you use two) whereas 2 six volts act as one and will not riunthe other battery. Your 5 watt solar panel isn't sufficient to recharge your battery; and , unless you have a two stage charger (one that equalizes your battery) you are not fully charging your battery and you will shorten it's lifespan. You need enough solar panel power and a good charge controller in order to bring the battery up to full charge. The cost will be around $500 to $1200 depending on how many batteries you want to charge and how much power you use during the day. Check on AM Solar's website. They have a very good explanation of how 12 volt batteries and solar chargers work as well as giving a table to figure your usage.
Crossfire is offline   Reply With Quote
Old 09-02-2008, 06:47 AM   #5
Head Rambler
You don't say which unit you have but most newer units have 3 stage chargers built into the converter (not inverter ) so they do a really good job of charging your battery(s).
My personal opinion is that adding a battery to your already existing battery is fine. Then in a couple of years you can replace both of them with a larger size if you need to. If you added a battery to an old and failing battery that's where you'd have problems.
Gotta go campin!
Bama Rambler is online now   Reply With Quote
Old 09-02-2008, 08:58 AM   #6
Cyber Phrenologist
Radio's Avatar
Originally Posted by steveqvs View Post
Thanks Radio,
Yes, either the generator or the grid will charge your battery just fine. And it's likely pretty efficent.
Yes, you can add a battery, same type and group number, etc, but having two matched batteries works better. There will be some loss in efficency, but not much. Get a cheap battery for now, to go witht the one you have, and when they finally crap out get two really nice identical batteries.
There is "good" and then there is "best" if you follow me...
KU4OJ
Old 09-02-2008, 12:05 PM   #7
steveqvs's Avatar
Okay those are all good informative posts. I think my converter is called a wifco.. something like that. it does seem to charge the battery fast and good. I was out reading last night and I read about the 2 6 volts in series. That does sound good. But I do think my plan will be to get as near as possible to the current battery untill those go bad and then replace some point down the road to the 6 volt batteries.
The solar panel comment surprised me some. I go to my camper about every weekend sometimes it 2 weeks apart but the battery indicator always shows full charge. I figured this as a trickle charger to get the battery charged during the week. Sounds like I better look into that somemore. thanks to everyone for the help... its all pretty new to me. We used to do a lot of tent camping... this is much different...
Old 09-02-2008, 10:18 PM   #8
Dave_Monica's Avatar
As far as charging directly off the generator, the battery charging will be unregulated and you may potentially overcharge. The best method is to charge the batteries through the convertor (charging is regulated) or by using an automotive battery charger...10 amp is sufficient. In an emergency, the automotive battery charger will also keep your 12v system going if your convertor were to crap out.
Old 09-03-2008, 04:29 PM   #9
steveqvs's Avatar
okay thanks
Old 09-11-2008, 12:22 AM   #10
NWJeeper's Avatar
Check out this site. It is my "Bible" for everything 12 volt related.
http://www.ccis.com/home/mnemeth/12volt/12volt.htm
Simply put, 2 6volt golf cart batteries are much better that 2 12volt batteries.
Converters in most all but the really expensive RVs only put out 12volts so charging is not at all efficient or complete through the on-board coverter no matter if you use generator or shore power. I will sometimes use a standard automatic type of automotive car charger which actually adjusts voltage to the charge state of the battery bank.
Check out the site above, it's a godsend to the dry-camper....
battery
