Old 05-01-2013, 12:28 PM   #1
QuietTimes's Avatar
Extreme basic 12V help....
I do 110 wiring all the time and understand installing lights, switches, and receptacles.
However 12V mystifies me. I want to tie into a 12V source in the TT basement and see a wire running to the hitch light where I could get a power connection. However I don't know one wire from the next. I see red, white and black. The red connects to black. White to white.
The power male piece I have for my led's has a red and a black wire.
Question is - what wire/wires do I tie into and what color to what color?
Can I use regular mar connectors of the correct size for the wires?
Thanks - apologies for being so uneducated about this.
Heather & Jim
2012 Ford F150 EcoBoost
2013 Rockwood 2703WS
Days camped 2012 - 14 (not enough); Days camped 2013 - 41 (May - 3; June-16; July-10; Aug.-12) Still not enough...
Days camped 2014 - 23
QuietTimes is offline   Reply With Quote
Old 05-01-2013, 12:30 PM   #2
TURBS's Avatar
White should be ground black should be 12v
Double check this with volt meter as your results may very.
On your item with red and black wire.
Red hot black ground.
Turbs
Old 05-01-2013, 12:52 PM   #3
QuietTimes's Avatar
WOW Turbs - you are fast!
So in my case the trailer wiring is red and white. So put the red pigtail wire to the red trailer wire and the black pigtail wire to the white trailer? Would be simpler if they were consistent on color.
My only voltmeter plugs into 110 receptacle. Can I use a battery tester set to 12V? Can I assume that the hot will show power and the ground/neutral will show nothing?
Seems like I need to make a trip to the hardware store for a proper voltmeter.
Thanks again Turbs. What would we all do without you....
Heather & Jim
Old 05-01-2013, 01:30 PM   #4
Lynkage's Avatar
That would be a good purchase and tool for the TT!
Shane & Antoinette
2012 Ford F-450 SuperDuty
2013 Crusader 355BHQ
Lynkage is offline   Reply With Quote
Old 05-01-2013, 02:34 PM   #5
TURBS's Avatar
Yes purchase one and leave it in the camper.
Good luck.
Old 05-01-2013, 02:38 PM   #6
buffalohunter's Avatar
QuietTimes,
I have seen many colors of wires in 12 volt systems and I don't trust the common color code like you use in 110/220 wiring. A volt ohm meter is a must to be safe. I would also suggest an inline fuse be added also for safety of what ever you are adding. Also, if you are taking power from another device or light source remember that if for example the bulb goes out your added device may lose power as well.
Just my two cents worth :>)
2012 Rockwood Windjammer 3008 W
2007 Tundra Reg Cab 4X4 SR5 5.7L
buffalohunter is offline   Reply With Quote
Old 05-01-2013, 03:10 PM   #7
Fire Instructor's Avatar
You'll find a number of threads that point out thet the Automotive indiustry uses red for + amd white for -, while the RV industry uses black for + and white for -.... And then OTHER threads where a different manufacturer did something different yet!
A multi-meter, even one of the cheap "free" one's from Harbor Freight, is a necessary tool to do any real electrical work in an RV....
Fire Instructor
2014 RAM 2500 Laramie 4x4 Quad Cab w/Cummins Turbo Diesel, 2009 Rockwood 2607, and 3 'yaks!
300W of Suntech Solar, a Rogue MPT-3024 Controller, and a Xantrex PW2000 Inverter
Fire Instructor is offline   Reply With Quote
Old 05-01-2013, 03:27 PM   #8
Herk7769's Avatar
My camper has about 1/2 the runs as green and white.
HAM CALLSIGN - KC3FFW
Old 05-01-2013, 03:45 PM   #9
Powerblast's Avatar
As a low voltage tech,I can tell you that when it comes to wire colors there is no hard fast rules. As far as light bulbs go - there is no polarity with incandescent bulbs I.e. one wire positive one negative With LEDs this may or may not be true. If the wires are the same color, say both white, then polarity does not matter, but if different color such as one red and one black, then most likely the red is positive and the black is negative /ground. If you get it Wong you can blow the LED but most of the time it just won't turn on. Always read the package and check current with volt meter.
Powerblast
Virginia Beach
2007 Tocoma / 20013 SP-240 BR
Powerblast is offline   Reply With Quote
Old 05-01-2013, 06:24 PM   #10
Himcules's Avatar
are you trying to tie into the tow vehicle's power? or into the trailer's house battery bank?
you can request a wiring diagram from forest river. they have it for 12v as well as 120v.
if you need power from the tow vehicle, here's the standard wiring diagram
Trailer Wiring Diagrams | etrailer.com
himcules (10x stronger than hercules)
2013 Forest River Berkshire 390BH-60
ex 2007 Jayco Greyhawk 31SS
Himcules is offline   Reply With Quote
