03-15-2014, 01:14 PM
TeresaInCAL
F150 not recognizing electric jack
So the new truck, 2013 f150, somehow isn't recognizing the jack. Plugged the jack in, nothing. Plugged the jack into the old truck, and jack works fine. So....any ideas?
Teresa
2013 f150 Ecoboost 4x4
2009 Gray Wolf, 22BH
03-15-2014, 01:34 PM
TeresaInCAL
The jack is a Trailer Star brand.
Teresa
03-15-2014, 01:36 PM
H2oski
Does the new truck have the fuse or relay install for BATT charging through the 7 way plug?
My old truck did not come from the factory with them installed. Just an idea.
Good luck
Wife
2007 Chevy 2500 HD 6.6
2012 Sabre 31RETS
(LA) Lower Alabama
03-15-2014, 01:38 PM
H2oski
Do you have 12 volts at the 7way plug and a good ground on the new truck?
Wife
2012 Sabre 31RETS
(LA) Lower Alabama
03-15-2014, 01:42 PM
Oklahoma Proud
Look in your glove box for a fuse. Also read owners manual about trailer tow or trailering. Most Gm and ford trucks will need need a fuse installed for trailer brakes and or trailer power. Some with the tow package will include the fuse in the glove box or behind the rear seat.
MillerTime- Future Sabre Handler!!
03-15-2014, 01:45 PM
You have a blown fuse in your truck. I had the same thing on my f250. Look at the schematic in your owners manual and find the fuse that powers the 7 pin.
03-15-2014, 01:49 PM
TeresaInCAL
I plugged the trailer itself (different plug from jack) into new truck, and the lights on the trailer work, so I'm assuming the truck plug is working fine. Have also used with horse trailer, and worked fine.
Teresa
03-15-2014, 01:51 PM
TeresaInCAL
If the fuse was blown, I assume the lights on the trailer wouldn't work, correct?
You have to forgive my ignorance when it comes to these things...
Teresa
03-15-2014, 01:56 PM
TeresaInCAL
I also pressed the red button (reset?) on the electric jack itself, to see if it would change anything, and it did not.
With the jack plugged in, I turned the truck off, and on again, to see if it would recognize the jack...nothing.
In the options area on the truck, I named the jack, hoping it would recognize it, and nothing.
Teresa
03-15-2014, 02:07 PM
Oklahoma Proud
Im guessing your power wire on your truck is missing the fuse. I can look monday when I get to work and tell you where it should be exactly.
Does your electric jack not work off your house battery? I've never had a tt so I don't know. On 5ers the jacks are powered by the trailer battery.
03-15-2014, 02:17 PM
TeresaInCAL
This particular jack doesn't have a separate wire to use off of a house battery. There is only a cord for the truck. (I'm not thrilled with the way the jack is set up to run like that, but am living with it, until it dies)
Teresa
03-15-2014, 02:35 PM
Mod free 5er
If everything else works on the trailer, suggest having the jack wired to the trailer battery. That is a less than stellar idea to have to be plugged into the truck to work the jack.
03-15-2014, 02:42 PM
TeresaInCAL
Ok, after Hubby did some checking on the net, we found it! It was fuses 9 & 21 were not plugged into the truck! We found them in a plastic Baggie in the glove box! Plugged the fuses into truck, and now the jack works! Woohoo!!
Thank all for your help!
Teresa
03-15-2014, 02:46 PM
Oklahoma Proud
X2
03-15-2014, 02:48 PM
Oklahoma Proud
Good deal! I've seen tons of those in trucks I've worked on and had to install a few fuses for others with trailer wire issues.
TeresaInCAL
Yes, I agree that would be ideal. Putting it on my to do list!
Teresa
03-15-2014, 02:49 PM
Mod free 5er
See post #12 again.
03-15-2014, 02:52 PM
TeresaInCAL
Yes, that's what we'll do soon as we can. Thanks for your help!
Teresa
