Old 06-21-2012, 12:08 AM   #1
My fan motor under the dash won't come on.
I dint have an owners manual so i dint know which fuses is for the fan motor so...,...
I pulled ALL the fuses and they are all good. I checked and there is no power going to the fan motor. The motors ok, all fuses ok..... Next step?
Alumaman is offline   Reply With Quote
Old 06-21-2012, 08:43 AM   #2
Well, first, is it a Ford Chassis, Chevy, or something else? Next, if you have no power to the fan motor, how do you know it is good?
Now for a little help. It should be a 30 amp fuse. Also has a speed control. Some even have a relay, for Ford, it is in the under hood fuse box. Try it on all speeds, if it works on high, then it is the speed control. If the fuse is good, and has power on it with the key on, then you are left with the switch, or the relay,
Ford manuals can be found here:
http://www.motorcraftservice.com/vdi...&menuIndex1=16
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 06-23-2012, 11:00 PM   #3
Ford Chassis.
Checked motor, it's good
No power to motor
Found fuse under stairs by batteries
Thank you for the link, hope I can find my chassis
