Originally Posted by TitanMike
If the factory was to pay more attention to detail and pay the Dealers less for their PDI work (which is in many cases just pocketed, the cost to the consumer wouldn't be a lot more than what it is now.
More inspectors to sign off on wiring, plumbing, gas, etc before it's covered up would lead to less work to be done by dealers as the units are prepped for the customers.
If the factories produced a finished product the only thing the Dealer would have left to do is wash whatever dirt accumulated on the unit as it was transported and unbox any accessories that were shipped inside the unit.
What they are doing now is no different than what the car manufacturers were doing back in the late 70's and early 80's. Push the vehicles out the door and let the Dealer take care of any finish work. I bought a special order Turbo Mustang in 1980. The body was covered in factory mistakes from dents from the inside that just got painted over to doors that didn't fit the opening and you could see daylight from the inside. Care spent about a month getting "finished" by the dealer.
As for the Dealer failing to perform a full PDI and correct flaws, the only way to cure that is to remove their "franchise" but as we are all aware, another manufacturer would be more than happy to sign up the dealer after getting cancelled by another.
Nothing will change as long as people accept what the factories and dealers push on them.
I guess I'm pretty lucky as I haven't run across any blatant flaws in wiring or plumbing (just one kinked propane hose for the bbq). I've just been busy upgrading the 12V system to meet MY standards (more current capacity with lower voltage drop between batteries and load distribution panel/charger). On that note just how much more does it cost to put one or two sized larger wire between converter and battery along with a few more feet of "wire loom" where wires are exposed in the "A-Frame" area of the hitch/tongue.
I have a fiver my Coachmen, bought just after Forest River took them over. I had quite a few problems got that I got fixed fairly quick and then other things started happening like doors falling off the hinges. I called the factory and there come back was well it's a trailer and it vibrates what do you expect. I told him that if you had quality stuff it wouldn't happen all it would take is one drop of super glue on those push in inserts for the hinges and they will not come out. He said they weren't going to take the time to do that. So guess what I've done with Forest River and everybody should stop buying from them without attitude. I've had this unit for 4 years and still can't get much water out of the kitchen faucet thought maybe it was a Kinked hose, I can't find it so I called the faucet Factory and they sent me a new one we'll see what that does.
