Old 01-31-2016, 12:19 PM   #11
Too Tall's Avatar
Thanks Turb, I'll take a look, did you mount the delay in the ceiling or at the thermostat.?
Also, Were the heck is the relays for the fan and compressor? My schematic doesn't show a relay.
Rockwood 2104S, 2014 Ram 2500 Diesel.
USMC 68 -70
Too Tall is offline   Reply With Quote
Old 01-31-2016, 12:21 PM   #12
TURBS's Avatar
I mounted it in the a/c unit.
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
Old 01-31-2016, 12:30 PM   #13
Too Tall's Avatar
Thanks, that's what I was planning although my thermostat is different than yours but I can figure that out. My old mind just is not working very fast these days.
USMC 68 -70
Old 02-01-2016, 04:08 PM   #14
I. used a,
Packard PTD102 Delay on Make Timer Relay TD69 ICM102
you can find them on e-bay and it's very easy to install.
danc is offline   Reply With Quote
Old 02-01-2016, 06:11 PM   #15
Too Tall's Avatar
Thanks Danc,
I don't know if those will work on my system as it is a 12 v DC thermostat. I called ICM and they said it was designed for 24 volt AC system. The only one I could find that is designed to work with DC 12 was the Dayton. Considerably more money than the ICM however.
Dayton Encapsulated Timer Relay, 1A, Solid State 2A562 | Zoro.com
USMC 68 -70
Old 02-01-2016, 06:33 PM   #16
TURBS's Avatar
Fan Delay Relay for Coleman Mach
The one listed on my thread works fine.
My unit is 12 v as well as everyone else's that installed the module.
Cut the fan wire put a female spade on both ends and plug into delay box.
Set timer and done.
2015 Columbus 320RS
2008 2500HD Duramax
Old 02-01-2016, 06:39 PM   #17
Originally Posted by Too Tall View Post
Thanks Danc,
Too Tall,
I used this same one on my micro lite and it works fine... mine is 12v as well. For around 10 bucks it may be worth a try. I think it would work for what you want to do.
Old 02-01-2016, 07:04 PM   #18
Too Tall's Avatar
Thanks guys, I'm probably too anal.
Have any of you installed a hard start capacitor and if so, did you see any benefit?
thanks in advance
USMC 68 -70
Old 02-01-2016, 07:29 PM   #19
TURBS's Avatar
I did, but really didn't notice a difference.
2015 Columbus 320RS
2008 2500HD Duramax
Old 02-01-2016, 08:38 PM   #20
thanks in advance
I did and it made a noticeable difference starting my a/c with my gen.
fan
