Old 02-01-2016, 10:39 PM   #21
Too Tall's Avatar
Thanks, I'm putting the SPP6 in, I hear good and bad but it's very popular. The Coleman factory tech told me it should help. He also liked the idea of a time delay.
Rockwood 2104S, 2014 Ram 2500 Diesel.
USMC 68 -70
Too Tall is offline   Reply With Quote
Old 02-02-2016, 01:51 AM   #22
Originally Posted by Too Tall View Post
Thanks guys, I'm probably too anal.
Have any of you installed a hard start capacitor and if so, did you see any benefit?
thanks in advance
Tried one on the traler I have now and it didn't make any difference trying to run the 13.5 AC with a 2000 watt Inverter Genny. So I purchased another Genny and parallel kit. Works great know.
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting - Boon Docking 99% of the time.
2009 F150 - 5.4 Litre - 6 speed - Tow Package
boondocking is offline   Reply With Quote
Old 02-02-2016, 04:48 AM   #23
Witch Doctor's Avatar
Yea, your right, hi and low would be better to delay. Wouldn't you need two of these delays to do both high and low? One for each wire?
If you are using the Coleman thermostat you will need to use a relay for each high and low speed. Check the color of the wire connections on the subase. I think 1 is gray and 1 is green. Then drop your R/A grill that is where your wires hook to the A/C board install them there. DO NOT TIE them together the high and low speed to 1 relay. You for sure will smoke your subase. The relay Turbs showed should work for your fan even if it is rated for 18 volt. The spp6 has to connect to your start/ run capacitor at the unit on the roof. That would be a must IMO for a ginny.
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 02-02-2016, 06:27 AM   #24
TURBS's Avatar
Fan Delay Relay for Coleman Mach
That's because you need 2500 minimum running watts for a dometic a/c, more for a Coleman a/c
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
Old 02-02-2016, 07:04 AM   #25
Who Dares, Wins
doc73's Avatar
I could run my dometic off one eu2000. Just had to have the fridge off 120. Worked fine as just a test.
Sent from my SAMSUNG-SM-G870A using Tapatalk
Pat, Jen & Heather... Oh yeah and our trained attack trailer cat, Cinnamon
2015 ChevyHD D-Max
2014 Greywolf 26DBH
doc73 is offline   Reply With Quote
Old 02-02-2016, 09:07 AM   #26
Too Tall's Avatar
Thanks for this. Yes, I have a GL and a GH, (fan low and fan high) at ceiling unit so I couldn't figure out how to delay both with one unit. I'm going to start with one delay and probably stay with one to keep the generator load lower (low fan). The 13.5 BTU is overkill for my little 21' Rockwood so low fan will be fine and will draw less amps.
The folks using the 18 VAC delays seem to have good luck with them with 12 v.
USMC 68 -70
Old 02-02-2016, 09:38 AM   #27
Too Tall's Avatar
Wow, what size unit is that?
USMC 68 -70
Old 02-02-2016, 10:03 AM   #28
TURBS's Avatar
I bet not in hot humid air
2015 Columbus 320RS
2008 2500HD Duramax
Old 02-02-2016, 02:09 PM   #29
Who Dares, Wins
doc73's Avatar
2015 Columbus 320RS
2008 2500HD Duramax
It was above 95 in the summer. It was not the optimal way to run, I do not want to do all the time. Just wanted to see if it could be done. It is a 13. 5 unit. It did help fire up the ac much cleaner when on both Hondas. No more lag.
I will say it would trip on one geni if I ran it for a few minutes then shut off and did not let the ac pressure equalize out. But again, I will not run on just one, just wanted to push the limit to see if it could and it worked fine so long as power was monitored to everything else.
2015 ChevyHD D-Max
2014 Greywolf 26DBH
Old 02-02-2016, 03:16 PM   #30
Too Tall's Avatar
those little honda's are a great machine. Yea, I'll open every circuit in the breaker panel but the AC when I try it. I'm working with 2400 wt max, 2100 wt continuous.
USMC 68 -70
fan
