01-31-2016, 01:59 AM
Fan Delay Relay for Coleman Mach
Does anyone have link to purchase a fan delay relay and also instructions on installation wiring. (I see mention of it but haven't been successful in a search) Also can the relay control the condenser and evaporator fans? Thanks in advance.
Rockwood 2104S, 2014 Ram 2500 Diesel.
USMC 68 -70
01-31-2016, 05:50 AM
Too Tall, Check out Granger. They will have a delay. You can delay the evap fan on start up. More then likely your going to have a double shafted motor in the unit. You only need to delay it long enough to get your compressor out of the start winding, we are talking seconds here not minutes. You would be better off to install a hard start cap on the compressor to pop it out of the start. If that is what your trying to do. That's where your amps will go up the most. The fan is not much at all. Just my opinion.
Coachmen M/H
Concord
2018 / 300 DSC
01-31-2016, 06:57 AM
Fonzie
01-31-2016, 09:48 AM
That's it[emoji674][emoji674][emoji674][emoji674]✌️
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
01-31-2016, 09:52 AM
Thanks, I'd like to install the hard start also but delay the fan motor until the compressor cranks. I think I can save about 4 to 5 amps startup load if I wait and start the fan after the compressor. Double shaft, yes I think you are right on that, thanks.
USMC 68 -70
01-31-2016, 10:34 AM
A/c fan draws 6 amps on a cool day
2015 Columbus 320RS
2008 2500HD Duramax
01-31-2016, 11:29 AM
Anyone have a schematic of how the time delay is wired using 12v? I'm think I would wire it to the low fan only. What's the 120 v wire what it says to cut? Also, the spec say, 18 to 120v. Will it work with 12? Thanks.
USMC 68 -70
01-31-2016, 11:34 AM
That's what you delay is the fan.
Open up your thermostat and see which wire is your fan power then go to a/c unit and install the delay in that wire.
I wouldn't just delay the low.
If that's truly what you want to do then again open your thermostat and see what your low fan speed wire is, then go to your a/c unit and delay that wire.
Problem is you always have to have fan on low when starting a/c
2015 Columbus 320RS
2008 2500HD Duramax
01-31-2016, 12:19 PM
Yea, your right, hi and low would be better to delay. Wouldn't you need two of these delays to do both high and low? One for each wire?
USMC 68 -70
01-31-2016, 12:24 PM
No, only one delay is needed.
In your thermostat is a high and fan wire.
The fan wire is the one you want, mine happened to be red.
2015 Columbus 320RS
2008 2500HD Duramax
01-31-2016, 01:19 PM
Thanks Turb, I'll take a look, did you mount the delay in the ceiling or at the thermostat.?
Also, Were the heck is the relays for the fan and compressor? My schematic doesn't show a relay.
USMC 68 -70
01-31-2016, 01:21 PM
I mounted it in the a/c unit.
2015 Columbus 320RS
2008 2500HD Duramax
01-31-2016, 01:30 PM
Thanks, that's what I was planning although my thermostat is different than yours but I can figure that out. My old mind just is not working very fast these days.
USMC 68 -70
02-01-2016, 05:08 PM
I. used a,
Packard PTD102 Delay on Make Timer Relay TD69 ICM102
you can find them on e-bay and it's very easy to install.
02-01-2016, 07:11 PM
Thanks Danc,
I don't know if those will work on my system as it is a 12 v DC thermostat. I called ICM and they said it was designed for 24 volt AC system. The only one I could find that is designed to work with DC 12 was the Dayton. Considerably more money than the ICM however.
Dayton Encapsulated Timer Relay, 1A, Solid State 2A562 | Zoro.com
USMC 68 -70
02-01-2016, 07:33 PM
The one listed on my thread works fine.
My unit is 12 v as well as everyone else's that installed the module.
Cut the fan wire put a female spade on both ends and plug into delay box.
Set timer and done.
2015 Columbus 320RS
2008 2500HD Duramax
02-01-2016, 07:39 PM
Thanks Danc,
Too Tall,
I used this same one on my micro lite and it works fine... mine is 12v as well. For around 10 bucks it may be worth a try. I think it would work for what you want to do.
02-01-2016, 08:04 PM
Thanks guys, I'm probably too anal.
Have any of you installed a hard start capacitor and if so, did you see any benefit?
thanks in advance
USMC 68 -70
02-01-2016, 08:29 PM
I did, but really didn't notice a difference.
2015 Columbus 320RS
2008 2500HD Duramax
02-01-2016, 09:38 PM
thanks in advance
I did and it made a noticeable difference starting my a/c with my gen.
