Old 01-31-2016, 12:59 AM   #1
Too Tall's Avatar
Fan Delay Relay for Coleman Mach
Does anyone have link to purchase a fan delay relay and also instructions on installation wiring. (I see mention of it but haven't been successful in a search) Also can the relay control the condenser and evaporator fans? Thanks in advance.
Rockwood 2104S, 2014 Ram 2500 Diesel.
USMC 68 -70
Too Tall is offline   Reply With Quote
Old 01-31-2016, 04:50 AM   #2
Witch Doctor's Avatar
Too Tall, Check out Granger. They will have a delay. You can delay the evap fan on start up. More then likely your going to have a double shafted motor in the unit. You only need to delay it long enough to get your compressor out of the start winding, we are talking seconds here not minutes. You would be better off to install a hard start cap on the compressor to pop it out of the start. If that is what your trying to do. That's where your amps will go up the most. The fan is not much at all. Just my opinion.
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 01-31-2016, 05:57 AM   #3
fonzie's Avatar
Here is one thread....
air conditioner for generator mod
Fonzie
Nights Camped: 2011(21) 2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36)
Old 01-31-2016, 08:48 AM   #4
TURBS's Avatar
That's it✌️
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
TURBS is online now   Reply With Quote
Old 01-31-2016, 08:52 AM   #5
Too Tall's Avatar
Thanks, I'd like to install the hard start also but delay the fan motor until the compressor cranks. I think I can save about 4 to 5 amps startup load if I wait and start the fan after the compressor. Double shaft, yes I think you are right on that, thanks.
USMC 68 -70
Old 01-31-2016, 09:34 AM   #6
TURBS's Avatar
A/c fan draws 6 amps on a cool day
2015 Columbus 320RS
2008 2500HD Duramax
Old 01-31-2016, 10:29 AM   #7
Too Tall's Avatar
Anyone have a schematic of how the time delay is wired using 12v? I'm think I would wire it to the low fan only. What's the 120 v wire what it says to cut? Also, the spec say, 18 to 120v. Will it work with 12? Thanks.
USMC 68 -70
Old 01-31-2016, 10:34 AM   #8
TURBS's Avatar
That's what you delay is the fan.
Open up your thermostat and see which wire is your fan power then go to a/c unit and install the delay in that wire.
I wouldn't just delay the low.
If that's truly what you want to do then again open your thermostat and see what your low fan speed wire is, then go to your a/c unit and delay that wire.
Problem is you always have to have fan on low when starting a/c
2015 Columbus 320RS
2008 2500HD Duramax
Old 01-31-2016, 11:19 AM   #9
Too Tall's Avatar
Yea, your right, hi and low would be better to delay. Wouldn't you need two of these delays to do both high and low? One for each wire?
USMC 68 -70
Old 01-31-2016, 11:24 AM   #10
TURBS's Avatar
No, only one delay is needed.
In your thermostat is a high and fan wire.
The fan wire is the one you want, mine happened to be red.
2015 Columbus 320RS
2008 2500HD Duramax
fan
