Fan-Tastic Fan not working
Hi All!
Our Create-a-Breeze Fan-Tastic Fan FWD8000 in our 2010 Rockwood Roo quit working.
I checked the fuse and it is fine. I followed the advice from another thread and went up top and checked the plunger switch and it was not stuck and seemed to be fine as well but I cleaned it anyway. At one point when I was up there and cleaning the lid, the fan suddenly turned on and started working again, but when we shut it off and tried it again, it would not turn back on. I was thinking loose wires so I climbed back on top and tried to take it apart to check the wire connections, but I cannot figure out how to get to where the connections are. Is the motor a sealed unit? Do I need to take the entire fan assembly apart in order to check the other connections? I would assume not as I see that the fan, motor and bow-tie bracket assembly can be replaced. I figured out how to remove these parts but can't figure out how to get to where the wire is attached to disconnect it (or reconnect a new one) anyway. I would really rather not have to pull the whole thing apart including where it is sealed to the roof. Can anyone point me in the right direction?
Thanks!
Well, nevermind... I just went back out there and it is working again. Hopefully it stays that way. I can't figure out how to delete this thread.
2010 Rockwood Roo 23RS
2015 F150 Lariat Supercrew 3.5l EcoBoost. Used to tow with 2006 F150 XLT Supercrew 5.4l V8. The EcoBoost is so much better!
