Old 02-13-2014, 05:01 PM   #11
Professional Curmudgeon
Originally Posted by dalford View Post
Kaadk, you never put more than one GFI on a circuit or they will might fight each other and continually trip when there is no ground fault. One GFI will protect all the circuits connected to it ( if it is installed correctly).
There's no reason you can't install more than one GFCI in a circuit. In fact, the installation instructions specifically address how to connect more than one in a series circuit.
2002 Forest River Flagstaff 8528RLS
2014 Coachmen Catalina 253RKS
2016 Keystone Summerland Mini 1750RD
2012 F250 Lariat 6.2L Crew Cab FX4
wrvond is offline   Reply With Quote
Old 02-13-2014, 07:41 PM   #12
You can add multiple duplex outlets to one GFCI outlet. I think if you check the installation instructions it shows you the terminals to add the down line duplex outlets ( non GFCI, standard ac outlet). The GFCI needs to be the first outlet ( connected to breaker) in the series chain as it is the outlet that has the circuit that senses all the current being fed to all the loads (multiple ac outlets). If the same amount of current going to all the loads is not sensed coming back from all the loads then the GFFI trips. This is a very small amount of current, as low as a few milliamperes. So, if you should conduct electricity through your body to ground the GFCI will sense it
There is no reason to have more than one GFCI outlet on a series of ac outlets and it must always be the first outlet from the breaker power.
2016 Siverback 33IK
2015 Ford F-250 Lariat 6.7L V8 Diesel 4WD Super Cab
Old 02-13-2014, 08:32 PM   #13
Old Bones's Avatar
Not sure if there would be a need to have GFCI feeding another GFCI in a trailer, but I do have that setup in our yard.
I have the GFCI outlet in our garage feeding another GFCI outlet in the garden that a fountain is plugged into. The one in the garden will trip if it senses an irregularity at the fountain, but the one at the garage will continue to work. The fountain will shutdown, but the lights plugged in at the garage GFCI outlet will still work. However I have had both trip at the same time on occasion.
2013 Forest River Surveyor SP296
Old Bones is offline   Reply With Quote
Old 02-13-2014, 10:17 PM   #14
On a very recent trip to So Arizona we had a recurring and annoying problem with the 15 Amp CB feeding the electrical outlets in our 2014 FR 26. Regardless of which of the 6 outlets in the trailer we used, we were unable to use more than 2000W at a time without tripping the breaker. I determined that all the outlets are wired to one 15 Amp breaker! (Probably the outdoor outlets too.) My task now is to connect half of the outlets to a new 15 Amp breaker. Why a company that has been making RV's forever wire a system like this.
Ccortes03 is offline   Reply With Quote
