Old 02-05-2014, 08:23 PM   #1
Few out lets do not work
So i have a heater in the trailer for winter and i have a wireless thermostat setup with it and i noticed was getting pretty cold in the trailer so i went to go turn the heater up a notch and noticed it want making any noise so i thought heater was bad, checked few other outlets and they were not working, but the TV outlet and microwave has power, forgot to check the bathroom outlet.. but anyway i have atleast 4 outlets that do not work i think the one by the sink was a GFCI but doesnt reset like a house one..
Checked the fuses and the breakers all looked good, so what do you guys think is wrong?
Thinking about it there may be a GFCI reset in the bathroom and of course i diddnt check there
Deeks is offline   Reply With Quote
Old 02-05-2014, 09:17 PM   #2
Kaadk's Avatar
My vote's for the bathroom one. In our TT the kitchen outlets are GFI'd off the bathroom one. Seems weird but I guess running the circuit all over is cheaper than a second GFI.
There's no use crying over spilt milk, unless it's on your keyboard.
Kaadk is online now   Reply With Quote
Old 02-05-2014, 09:30 PM   #3
?? I think they are like house ones. If it won't reset or trip (test button) then there is no power going to it. Have you checked the breaker panel. We kept blowing our 20 amp fuse when using our 1500 watt electric heater and would forget to turn it off before making coffee or using the microwave. Sounds like you might have 2 20 amp circuites. Check the breaker panel
2016 Siverback 33IK
2015 Ford F-250 Lariat 6.7L V8 Diesel 4WD Super Cab
Old 02-05-2014, 09:35 PM   #4
Kaadk, you never put more than one GFI on a circuit or they will might fight each other and continually trip when there is no ground fault. One GFI will protect all the circuits connected to it ( if it is installed correctly).
2016 Siverback 33IK
Old 02-05-2014, 09:37 PM   #5
onetonford's Avatar
My Fiver has two gfci's one is in the bathroom next to mirror and the other is under the cabinets in the kitchen area. one controls one side of trailer and the other one controls the rest. check yours it is possibly the same way....
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
onetonford is offline   Reply With Quote
Old 02-05-2014, 11:22 PM   #6
Kaadk's Avatar
Yeah, I know. What I don't understand is why they put it all on one circuit to began with. I would have done at least two circuits, one for kitchen, one for bath. Or at least one for port and one for starboard.
Old 02-06-2014, 04:01 AM   #7
Witch Doctor's Avatar
I just had the same problem, In my unit they have 2 15 amp breakers for all the outlets. On 1 that keeps tripping I found the Refer, TV, the outside outlet and 6 plain duplex outlets on the 15 amp circuit. The bath, bedroom and basement was on the second. Each has a GFI in each section. To make it even worst they doubled the 1st 15 amp and connected my converter to that breaker, that is against code to use two wires in 1 breaker. The thing that makes me mad is that I still had room for 2 more breakers in the panel. So I added a breaker for the converter to atleast separate that. If you have a volt meter check to see that you are getting 110v at the breaker first, then if you are check it at the GFI either at you kitchen area or in the bathroom. If your GFI will not reset it is bad. Hope it helps. Sometimes a breaker will look fine but it has tripped, so make sure you turn them off and back on again. You can look up a thread named 110 volt labels and see what I found and posted. When I called FR for a diagram, they said they do not have one it depends on who is on the production line that day doing the wiring.
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 02-12-2014, 09:21 PM   #8
just.a.jeep's Avatar
I had a GFI that wouldn't reset. Traced everything and found that a junction box under the slide had water in it. Cleared the water and all was well.
2014 Cedar Creek 36CKTS 2012 Dodge Ram 3500 LARAMIE
just.a.jeep is offline   Reply With Quote
Old 02-12-2014, 09:45 PM   #9
BillyBass's Avatar
You may have a loose connection in the fuse box that happen to me and when I pull out the breaker I found a loose wire.Which it wouldnt let me reset the gfi that in the bath until I tighten it. good luck
2012 21' FR Micro Lite FBRS
2005 GMC Sierra 1500
2012 24 nites 2016 16 nites
2013 25 nites 2017 19 nites
2014 14 nites
2015 16 nites
BillyBass is offline   Reply With Quote
Old 02-13-2014, 04:02 PM   #10
The snow stopped and i had time to check the trailer and the bathroom GFCI was tripped and i rest it and everything is working!
then i noticed the snow must of broke the bathroom vent cover, so now i need to find that part and replace it lol..
Anyway thanks guys!
