09-29-2019, 10:49 AM
Flagstaff Epro E19FBS problem
Hi. I need some help on electrical problem on our camper (epro E19FBS). On our 3rd day of camping at Ohio state metro park, we plugged too many things at once and now non of the outlets work. We checked all the fuses under the fridge, and they are all on.. did I break it😰? The main line from the park is working for sure. Thank you.
09-29-2019, 11:35 AM
Scoundrel
Find the GFI outlet (likely in the kitchen/bath) and hit the reset button.
2024 Geo Pro 15TB, 400W Solar, 2 Golf Cart batteries
2015 F-150 5.0L V8 XLT Crew Cab, 4x4, Tow Package, 36 gal tank, 3.55 locker, 1891 payload, Integrated Brake Controller, Roadmaster Active Suspension
Wooden Spoon Survivor
09-29-2019, 11:43 AM
Scoundrel
09-29-2019, 12:21 PM
Originally Posted by HangDiver
Ahhhh thank you for your reply. I found it in the bathroom and reset it. But still doesn’t work 😰
09-29-2019, 02:11 PM
Reset your inverter, no doubt... happened to me on our Geo 19FD. On our FD (thats the Murphy bed Model) the inverter is in the front left compartment behind a panel. Not sure where yours might be but, one of these folks surly will.
2021 Rockwood Mini-Lite 2506s
2022 Chevy Silverado Trail Boss
2018 Male Newfoundland
"No such thing as bad weather, just bad clothing..."
09-29-2019, 02:14 PM
Sorry Freudian slip with surly some of these folks are ornery... should be surely!!
BTW: your EPro is the same as a GeoPro, but I'm not sure how the models compare.
09-29-2019, 02:20 PM
For some reason, on our Work and Play, the outlet would not reset with power to it. I had to turn off the power, push the reset, and then the power back on.
09-29-2019, 03:01 PM
Check the circuit breakers in the panel on your converter (Shown here on right)
Circuit breakers shown at bottom with cover removed.
No need to remove the cover, just open the door for access.
Make sure that the breaker on the park's power outlet is on. Turn it off, then back on to be sure.
09-29-2019, 03:11 PM
melmax
I had the same problem with the same exact trailer.
just remove the access panel in the cupboard under the tv.
The invertor is in behind the access panel.
re-set the breaker on the invertor.
Its either on the top left or bottom left of the panel.
After re-setting the breaker on the invertor you will probably need to re-set the gfi.
09-29-2019, 04:06 PM
The outlets are controlled by a circuit breaker, not a fuse. Turn the breakers off and back on to reset.
Cedar Creek Lake, Texas
2019 Keystone Loredo 290SRL
Andersen hitch
09-29-2019, 04:28 PM
Thank you everyone for commenting and helping me through this! It finally worked by resetting the inventor. It is our first camper, and we are learning everything slowly 😆 you guys are amazing🥰
09-29-2019, 05:36 PM
What did you reset?
Andersen hitch
09-29-2019, 05:37 PM
Originally Posted by CedarCreekWoody
What did you reset?
They said they reset the "inventor". I think they meant the inverter.
09-29-2019, 05:40 PM
Scoundrel
Sometimes I wish we could reset the inventor.....
09-29-2019, 06:29 PM
Thanks Dan. I was baffled by that one. Glad they found it.
Andersen hitch
09-29-2019, 07:28 PM
Resetting inverter 😬 ☺️
09-29-2019, 07:38 PM
It is definitely your inverter there is a soft reset on the bottom of the inverter that is located in the front drivers driver's side of the trailer behind th card board. The reset switch is on the lower left side bottom just push it in to reset
09-29-2019, 08:42 PM
Thank you! It is fixed now 🥰
Yes. We did reset the inverter, and everything is working great now . Thank you 😊
09-29-2019, 09:51 PM
The OP already stated that they did that, back in post# 11.
