Old 07-17-2016, 09:15 PM   #1
stansoper's Avatar
Fluctuating lights on shore power.
2014 Wildwood 29kfbs. Lights fluctuate on shore power. I have Installed a Battery Disconnect switch. Turned off battery switch and lights quit fluctuating. I thought I would try that out with battery disconnected. AC and lights went out, then lights came back on. So I turned the battery switch on and checked AC, worked fine, but lights fluctuate. What the heck is going on???? When on shore power, how does the battery work with the converter?
stansoper is offline   Reply With Quote
Old 07-18-2016, 02:21 PM   #2
Head Rambler
Ours did that in an older unit, and come to find out it was a bad cooling fan in the converter. Every time the converter would become loaded either from turning on lights or from charging the battery it would limit on temperature and cause the lights to fluctuate.
Do you hear the fan in the converter running from time to time?
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
Old 07-18-2016, 09:26 PM   #3
stansoper's Avatar
Have not noticed any fan noise, but it's summer and with the AC on, it's hard to hear.
Old 07-23-2016, 01:10 AM   #4
Wild guess. Perhaps you have a wfco converter that can't decide to be at float voltage or absorption charge voltage. Or a wfco that is just dying?
Sent from my SAMSUNG-SM-G900A using Tapatalk
spaach is offline   Reply With Quote
Old 07-23-2016, 08:27 AM   #5
waiter21's Avatar
Sounds like the converter is changing voltage to charge the battery. How old is your battery? Is it able to hold a charge?
2001 Coachmen Mirada (Ford F53 6.8L V10) - Toad 2001 Civic
It won't do MACH 2, but I can get a sandwich and take a pee.
waiter21 is offline   Reply With Quote
Old 07-23-2016, 08:33 AM   #6
SeaDog's Avatar
Agree with converter causing fluctuation with that said I would also check and tighten all the connections at the converter.
Retired Navy
Jake my sidekick (yellow Lab)
2006 F350 6.0
2016 Flagstaff 26 FKWS
AF&AM of Idaho
Old 07-25-2016, 09:22 PM   #7
Watch those WFCOs. Mine started to smoke this weekend
jchiar is offline   Reply With Quote
light, power
