Old 08-01-2014, 06:21 PM   #1
Foot/Door light won't go out
Can somebody tell me how the door light /foot light below works? I've ruined batteries because it just won't go out. Driving me nuts. How do I fix this thing?
apollumi is offline   Reply With Quote
Old 08-01-2014, 06:28 PM   #2
Lloydg's Avatar
Send a message via AIM to Lloydg Send a message via MSN to Lloydg Send a message via Yahoo to Lloydg
You should probably state what kind and model number of RV you have. In any case, have you checked for any switches in your basement or any other compartments? Sometimes they put those switches up high so you have to really look good. Just my thoughts.
Heartland Big Country 3150RL
2013 Ford SD F250 4x4 SC; 6.2
Reese 18K Elite w/slider - Ada, Michigan
Lloydg is offline   Reply With Quote
Old 08-01-2014, 06:33 PM   #3
Sorry, it's a Cherokee 25RR toy hauler. There is no basement. I've looked around and can't figure out how it works so that I can fix it. Took it to the dealer once and they said it was fixed. Problem came right back though. Has to be a switch or sensor some place but I can't find it.
Old 08-01-2014, 09:04 PM   #4
If it is a mechanical switch, the plunger should be visible. My door has a magnet that operates a reed switch on the hinge side frame, low. It is the same kind of switch used in home security systems.
2014 Blue Ridge 3715BH <- Read the saga
2013 Sierra 3500HD Denali CCLB DRW 4x4 Duramax w/ Reese 20K
Camped: 2016=6, 2015=9, 2014=27
USN Retired (26 years), but not Retired retired
Home Port Orlando
Narboza is offline   Reply With Quote
Old 08-03-2014, 01:31 PM   #5
There is two plungers on the inside bottom of door but I think they give electricity to the keypad lock on the outside of the camper. It doesn't work unless the contacts are made.
Old 08-03-2014, 01:57 PM   #6
I should have been clearer. Look where the screen door seats, not the main door. Any magnet visible? May be built inside the door edge?
Home Port Orlando
Old 08-03-2014, 04:58 PM   #7
It's a little magnet bottom of door and close to hinge. Even said "lamp" on it. I tried putting a thicker rubber spacer in there to get it closer. No dice. What now?
I also took the magnet off, laid it down on the door frame moved it around slowly in the area it should go over, still no dice.
Old 08-03-2014, 05:37 PM   #8
The reed switch the magnet operates likely needs to be replaced. It would be rare to have the magnet lose its magnetism. You could try with a different magnet. In the interim, disconnect the wire to the light strip. The reed switch would be very close (<1/8") from the magnet with the door in the closed position.
Home Port Orlando
Old 08-03-2014, 06:11 PM   #9
I had this exact problem in my 21rr. I never could figure out how it worked. I took it back to the dealer while under warranty and they said they took it apart but couldn't find anything wrong with it. They put it back together and it worked and was still working when I sold it. I bought a new 27rr and it does not have that light. I added a battery cut off switch to the 19rr so it wouldn't drain the battery.
comfun1 is offline   Reply With Quote
Old 08-04-2014, 05:44 AM   #10
You could try removing the threshold and see what is under there.
Home Port Orlando
door, light
